is this a good set up??
Old September 27th, 2011, 12:15 PM   #1
Whitestang88's Avatar
1988 LX
Whitestang88 is on a distinguished road
ok i have a 1988 mustang lx SPEED DENSITY,160,000 km,currently i have some minor upgrade:
BBK headers
BBK offroad H-pipe
Flowmaster exhausts
underdrive pulleys
BBK CAI
and cobra upper/lower intakes(65mm Tb)
now i was planning on buying a cam and i did some reading and found out that magnum cams from compcams.com will be good for a stock motor with stock heads?
I plan to get a cam,some RR's, trickflow street upper/lower intakes,and 3:55s in the rear with a possible tune by dasilva in toronto after that,would that work if i wanted to stay with speed density?(keepin it OG)
thank you guys
Old September 28th, 2011, 05:51 PM   #2
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
You're not gonna make shit without some heads. I would keep the cobra in take and spend the money u were gonna spend on the trickflow to get some gt40 heads. You'll make a lot more power. And I know the Anderson n-41 cam works great with this combo. You will need a tune though since you're running speed density. I would recommended investing in a megasquirt system. Or call around at shops and see if they can tune speed density before you proceed with the build.
Old September 28th, 2011, 05:57 PM   #3
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
You really need to ditch the SD.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old September 28th, 2011, 06:49 PM   #4
Chris951's Avatar
1991 mustang 5.0
There's nothing wrong with speed density. Just takes a little extra tuning. And can run just as fast or faster than mass air. If he wants to keep it, then more power to him. I preferred how my SD cars drove over my 91. My 87 and 88 seemed to have less drivability issues. And the OP can get a megasquirt system and tune it himself to save ALOT of money down the road. That's what I would do if I had another SD car.
Old September 28th, 2011, 08:27 PM   #5
1988 LX
thanks for the advice man it helped alot!!!would u reccommend going with some 24# injectors also??
Old September 28th, 2011, 10:27 PM   #6
Chris951's Avatar
1991 mustang 5.0
Yeah I would with the setup I posted. Just make sure you get a tune or get a megasquirt kit because your car will not run lol. SD runs off vacuum so you might want a differenr cam. One with higher lsa numbers will work better with sd.
Old September 30th, 2011, 05:45 PM   #7
95StangMX's Avatar
95 Mustang GT
stock cam is best for stock top end period. Unless you change heads and have someone or you can afford the mega squirt or other tuner and can do it yourself like mentioned above, then go for it, but if you are just wanting it to have the "big cam sound" do not do it.
Old October 4th, 2011, 12:34 PM   #8
1988 LX
ok guys i think i decided(with much help)on what im gonna get
: 3:55s(already have),Cobra upper/lower intakes(already have),comp xe270 cam with 1.72 RR's should put me at .544 lift,24# injectors,GT-40 Heads ,sound good?oh and a heavy tune:p how much hp and tq u think ill be making with that?(and obv the other mods i got)
Old October 4th, 2011, 03:58 PM   #9
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
270 rwhp and 320 rwtq basic setup right there...
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Threads Similar to: is this a good set up??
Looking for good tune shop in NJ that is good with prochrger prochargerguy 2005 - 2010 5 February 20th, 2011 09:25 PM
Are GT500 KR struts/ shocks any good? Is this a good deal? jackhammer505 2005 - 2010 2 January 9th, 2011 09:15 AM
good running LS1 for 500 bucks good deal huh? BakerFX4 The Clubhouse 19 November 3rd, 2010 01:12 PM
I need good new tires - Are the goodyear eagle Gt's good? 00mustangv6 V6 Mustangs 0 December 21st, 2009 09:50 PM
