03 mustang gt
12.00
crank and rod
i have a man-o-war 302 block with 8.2 deck height, it seems this block uses the 351 crank (2.749 journals) which is min. 3.5 stroke, my plan was to go 363 - 3.4 stroke, 5.4 rod, 4.125 piston. since i have to use a 351 crank with the 3.5 stroke, will that put me above the 8.2 deck, if so can i use a shorter rod on this crank
Imports are like tampons, only PU$$Y's use them!!!
03 mustang gt
12.00
anyone??
89 Mustang
The block you have is a very strange set up. Not to upset you but from what I seen they were like a mistake and there are no more of them gone to be made. Yes they have a 3.5 stroke kit for the 8.2 block but it did not catch on that much due to ring lands being very problem prone but it used a 5.4 rod just like the 347 kits. But there is no telling if it would clear the counter weights unless you have talked with someone that has done it. Problem with running a 351 crank you are gone to run into the rod journals being to be for the 5.4 rod. but they do make a 3.5 stroke crank with the 2.1 rod journals that are common BUT a friend of mine just called about the Eagle crank and it would only work with a 6.00 rod with out gone and cutting the counter weights down. That leaves very few options and a custom crank looks to be in the works for you I do think or cutting down a Eagle or Scat unless they are making one now for your set up. I have seen them already out there for people that also got this block on a deal. So I know the crank grinders are making them but the cost is up there but in the end you would have a super nice darn near bullet proof set up that would take just about any thing you could throw at it. Look around over on like Yellow Bullet that is a much more hardcore race site and much more informed people then me that could help you out also and maybe tell you away around your problem. other then the custom crankshaft or a cut down one. good luck with it.
Just another turbo Mustang..No dyno numbers just good ets and MPH. And yes it is fast for a street car. few parts for sale https://docs.google.com/document/d/1...l=en_US&pli=1# |
03 mustang gt
12.00
thanks, from my hours upon hours of research it keeps coming back to needing a custom crank, looks like the "deal" i got on this block is gonna cost be more in the end
89 Mustang
Yes and I think that is a bit shity that they dont tell people up front when they are cutting "deals" on the blocks
Threads Similar to: crank and rod
| car won't crank | JoshDrex00gt | 99-04 | 13 | April 18th, 2011 08:41 AM |
| the 2.5 crank | lostchild | 2.3 Mustangs | 2 | January 5th, 2009 06:39 PM |
| HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? | the1968jeepthing | 99-04 | 2 | September 29th, 2008 11:39 PM |
| Crank ??? | 01gtMustang132 | 99-04 | 14 | September 20th, 2008 03:08 PM |
| crank | mpboy | 99-04 | 1 | February 20th, 2008 04:24 AM |
