Fuse problem
Old September 29th, 2011, 03:01 PM   #1
93 Mustang Gt
velasco98 is on a distinguished road
Fuse problem
I have dual electric fans and the fuse from the battery to the fans heats up and melts the plastic, but doesn't break the fuse. The fuse is a 20amp. Why does it melt it?
Old September 29th, 2011, 04:41 PM   #2
fogged306's Avatar
89 GT
What are the fans rated at? What gauge wire are you running? Melted fuses are pretty common when the wiring for the circuit is too small and heats up. Heat creates resistance which creates more heat and so on until you end up with a melted weak point, sometimes the fuse. I've never seen an electric fan with a 20a fuse rating, especially a dual.
Old October 1st, 2011, 03:06 AM   #3
93 Mustang Gt
I don't know what they're rated at. But I bought the wiring from summit for the fans.
Old October 1st, 2011, 03:07 AM   #4
93 Mustang Gt
What do you suggest I do to help prevent this?
Old October 1st, 2011, 10:19 AM   #5
fogged306's Avatar
89 GT
You need to do some digging and find out what the fans are rated at. What kind of fans are they? If you know that much, I'm sure some googling can tell you the turn on amperage and the constant draw amperage. IIRC taurus fans (just an example) can spike to over 80 amps when they first turn on and then draw something like 30-40A continuous. For those I would suggest quality 8ga wire and a solenoid to activate them.
Old October 2nd, 2011, 11:18 PM   #6
93 Mustang Gt
Ok thanks.
The brand is flex a lite
Old October 2nd, 2011, 11:46 PM   #7
1991 Mustang GT
UGOT8UP is on a distinguished road
Here is a good wright up on how to install aftermarket fans.
How To Properly Install An Electric Fan
Old October 3rd, 2011, 07:38 AM   #8
fogged306's Avatar
89 GT
That write up should give you all the basics you need to do it right. The fan you have draws 30-40 on start-up IIRC, so I would use at least 10ga wire for it. I have one of them and that's what I used with no issues. I've also since added a fan controller with a soft start feature, meaning when the thermostat in the controller hits the selected temp, the controller slowly starts and increases voltage until it reaches 60% power. Then keeps increasing the power as temps climb. I have an aluminum rad and the one in my car cools my 408 well enough that I have yet to see it go over that initial 60% power even when it sits and idles for a while in hot weather. It's nice because it's way quieter at 60% than full blast.
Threads Similar to: Fuse problem
electrical problem. fuse for taillights? v606er 2005 - 2010 12 July 6th, 2010 10:02 PM
Fuse problem Mr. Red Pony Audio/Video 1 May 8th, 2010 11:38 AM
Horn fuse problem bloodusmc V6 Mustangs 6 May 28th, 2009 08:57 PM
quick lil question about fuse problem WilltheThrill 4V / SVT 3 November 15th, 2008 01:36 AM
Fuse, problem with radio HELP!!! stingydonut 5.0 Mustangs 2 February 21st, 2007 05:50 PM
