Coyote 5.0 vs old school efi engines! - Page 2
LinkBack (1) Thread Tools
Old October 4th, 2011, 01:46 PM   #21
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
Originally Posted by 91cobra5.0 View Post
thats more strip than street, but deffinantly possible with a big headed high spining set up
If you call 6500RPM high spinning......
Yes its a pretty radical small block. Its solid roller, borderline pump gas compression. Its a work of art honestly to put a motor together like this BUT if I can make that with no blower. A 408 with 9:1 compression and a blower will rock his goals easy.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old October 5th, 2011, 10:48 AM   #22
jonrhy05 is on a distinguished road
this is a local guy who has poured some $$$ into his car to make 900hp
Old October 5th, 2011, 10:27 PM   #23
bioberg's Avatar
1990 Mustang GT
bioberg is on a distinguished road
Well if I DID do a coyote swap what transmissions are compatible? I like Automatics. Would the new 6 speed fit in the fox?
Old October 5th, 2011, 10:34 PM   #24
bioberg's Avatar
1990 Mustang GT
And is there anyone who makes a aluminum 363 block? If not whats the best 363 out there and would it be smart to put boost or nitrous in it?
Old October 6th, 2011, 12:35 AM   #25
1992 Mustang Lx 5.0 347ci
11.8@115
SloMo is on a distinguished road
My friend put a T-56 in his. I imagine the 4r70ws are compatible.
Slow Motion... Quick reving, High compression, Big Boy 347 stroker... STROKER MOTION...
Old October 6th, 2011, 09:42 AM   #26
fogged306's Avatar
89 GT
Is there a reason you're hung up on an aluminum block? Just because they're more expensive than the iron blocks doesn't mean it's going to do you much good. If you're more concerned about straight line performance, stick with an iron block that won't break the budget. My iron block weighs 195lbs and with the rest of the stuff I've removed from the car and even with the drag suspension I have on the car, it's not bad on the street at all around corners.
To get 363 cubes out of an 8.2 deck you need a big bore block. One that starts with a 4.125" bore as opposed to one that starts at a 4" bore. I would do a 9.5 deck if those are your power goals though. An SHP block is your best bet IMO.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/235056-coyote-5-0-vs-old-school-efi-engines.html
Thread Coyote 5.0 vs old school efi engines! | Forums at Modded Mustangs | BoardReader This thread Refback February 27th, 2012 06:36 PM
Threads Similar to: Coyote 5.0 vs old school efi engines!
Coyote Five-oh anyone?? PUNISHER08GT 2005 - 2010 75 November 10th, 2011 06:19 PM
No to the Coyote Jaa1456 99-04 31 August 22nd, 2011 06:53 PM
Coyote in a Fox PhillyGT 5.0 Mustangs 5 March 16th, 2011 06:49 PM
Pics of the coyote 69fastback The Clubhouse 16 January 20th, 2010 09:37 AM
Old School Meets New School... 06Stang Pictures 42 May 18th, 2008 10:39 AM
