1988 gt
no clue maybe 12.s
Do i need a chip or a tune for my setup
I have an 88 gt that has been converted to mass air with a9p,the motor is out of a 97 explorer.I have installed the following, 24lb inj., bbk 73 mm mass air meter, cold air, bbk equal shortys, comp cam .544 lift , trick flow spring kit, sotck 1.6 s, mallory tfi style dis.& street strip coil and a holly 185lph pump. this is my first project stang.
1992 Mustang GT
dont know yet
As long as your MAF is calibrated to your injectors the you don't NEED a tune. That being said a tune will get you the most out of your setup.
Sent from my Autoguide iPhone app
______________ Mods: Paxton Novi 2000 @10psi 3.73 gears 255lph fuel pump Lucas 42# injectors Trick Flow 75mm upper intake Trick Flow 75mm throttle body Diablo "MAFia" Dyno tuned by Force Fed performance Sacramento Ca |
91 Mustang GT
1991 sliver GT
tune would be the best bang for the buck. Check out the bama tunes.
1988 gt
no clue maybe 12.s
It's really tough in northern mi. as there are no speed shops around, not to mention the local dealer has little knowledge on the fox. bama tunes looks like the way to go, just to be able to switch your tune on the fly sweet. Any idea on what kind of hp my combo produce's ??????
89 GT
Don't expect a huge gain in HP over what you can do yourself with fp and timing on a mild combo like yours. The real gains with a tune for you will be in part throttle and mileage, assuming the tune is done correctly.
#6 | |
91 Mustang GT
1991 sliver GT
True. Timing and fuel helped more than the chip. The chip just kinda smoothed everything out.
1988 gt
no clue maybe 12.s
how much fp should I shoot for and shouldent my base timing be @like 12 deg.? also would i have to have the pistons fly cut to run 1.7s ? comp says that the actual lift is like .526 w/stock 1.6s
1992 Mustang LX
13.0 @ 105
You gotta measure for pistons to valve clearence...can't tell ya on here. But shoot for 38-40 psi of fuel pressure and 14* of timing...with the spout out.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
Threads Similar to: Do i need a chip or a tune for my setup
| Worthy of a Chip and tune? | Fee | 5.0 Mustangs | 6 | May 2nd, 2011 07:26 PM |
| dyno tune or chip | Cschneider_23 | 5.0 Mustangs | 5 | March 25th, 2011 07:44 PM |
| Chip and/or tune?? | TrueBlue756 | 2005 - 2010 | 4 | September 29th, 2010 02:20 PM |
| Chip or Tune? | poisonstallion95gt | 94-95 | 25 | November 8th, 2007 12:16 AM |
| Gears... or Chip and Tune | 2004GT | 99-04 | 11 | March 8th, 2007 02:38 AM |
