331 stroker or 351
LinkBack (1) Thread Tools
Old October 5th, 2011, 10:18 PM   1 links from elsewhere to this Post. Click to view. #1
cburns's Avatar
1989 mustang gt vert
cburns is on a distinguished road
331 stroker or 351
What would be pros and cons of going with a 331 stroker or just building a 351? I have the trickflow street heat top end kit. 70mm trickflow throttle body and 30lb injectors with 75mm mass air. Any suggestions? Car will mostly be a dd.
Prepare your brain for RAZZLE DAZZLE!
Old October 6th, 2011, 09:30 AM   #2
fogged306's Avatar
89 GT
If you keep the 351 stock stroke, then the 331 would probably be faster. Although if you're going to stroke a 302, you might as well go for a 347 instead of a 331. Unless you plan to spin it up well past 7k you're not going to have any issues with a 347 as compared to a 331. If you stroke the 351, then it's a no brainer. More cubes, block can handle more power. If you've got the cash to do the swap and stroke the 9.5 deck, do it.
Old October 6th, 2011, 09:41 AM   #3
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
I'd say if you already have a 302 block then stoke it because you can reuse your top end kit unlike a 351 where you'll have to get a new intake and headers to fit the block.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Old October 6th, 2011, 01:47 PM   #4
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Well that depends on what intake he has. If it's not a good intake, there's no use in waisting money on the stroker kit. So, he may have to buy that stuff anyways to make the stroker even worth it.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old October 7th, 2011, 04:27 AM   #5
cburns's Avatar
I have trickflow top end kit. I was leaning toward the stroker for that reason of already having everything. I just wanted to see if there was anything that would make it better to go with 351. Thanks for the input guys.
Old October 8th, 2011, 08:25 AM   #6
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Honestly, you might only see a 20rwhp gain going from a 302 to a 347.... you need a better combination to make a stroked motor worth it.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old October 8th, 2011, 09:54 AM   #7
cburns's Avatar
Maybe this is a better question. I have trickflow street heat top end kit, cold air, 75mm mass air, 70mm throttle body, 30lb injectors 190lph fuel pump, adj fuel reg. Electric fan, Mac pro chamber h pipe no cats and flows and 3.73 gears 5 lug conversion. I have already budgeted for headers and bigger aluminum radiator, clutch and harmonic balancer. so with all that I was wanting to do the 331. If I don't do 331 I would still need to buy pistons bout 500 bucks. Stroker kit cost 1000. If y'all don't think my top end kit is good enough for stroker or is not worth the money what would y'all get with the extra 500 dollars?
Old October 8th, 2011, 02:04 PM   #8
Burn'nRubber's Avatar
1992 Mustang GT
Coming soon...
Burn'nRubber is on a distinguished road
^ Spray the bitch.
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/235529-331-stroker-351-a.html
Thread 351 stroker parts, 351 swap items & AFR 205's (re-list) allot of pictures | Corral.net: Ford Mustang Forums | BoardReader This thread Refback November 4th, 2011 10:30 AM
Threads Similar to: 331 stroker or 351
Stroker kit DegralDan 99-04 0 April 24th, 2010 11:08 PM
4.6L Stroker kit energiesource 99-04 9 November 1st, 2007 01:22 AM
4.2L stroker blazor V6 Mustangs 7 October 30th, 2007 12:18 PM
351 or 460 stroker Iownastang 5.0 Mustangs 17 October 23rd, 2007 10:01 AM
To Stroker or Not to Stroker? That is the Question! 87StangLX General Tech 13 October 20th, 2007 10:46 AM
