Piston clearance???
Old October 7th, 2011, 12:09 PM   #1
1989 Mustang GT
89fordified is on a distinguished road
Piston clearance???
I want to know if i will have any issue with piston to valve clearance with some heads with 1.94intake and a stage 1 trick flow cam---499/510...will I need to flycut pistons or will i be ok Jus installing everything??? Help
GT40 Crate motor, BBK cold air intake, BBK headers, B&M shifter,BBK Springs, Off Road H-Pipe dumped off exhaust, Flowmaster
Old October 7th, 2011, 01:10 PM   #2
Mustang Boy's Avatar
1994 Mustang GT
14.582@92.58MPH
Mustang Boy will become famous soon enough
Send a message via AIM to Mustang Boy Send a message via MSN to Mustang Boy Send a message via Yahoo to Mustang Boy
Cool
Listing what heads you have might help.
315's Crew
Black and White Crew
Crew Member #2
Old October 7th, 2011, 01:55 PM   #3
1989 Mustang GT
I have some ported dart Windsor Jr heads
Old October 7th, 2011, 01:55 PM   #4
fogged306's Avatar
89 GT
You need to measure, no way to tell you this for sure over the internet.
Old October 7th, 2011, 02:06 PM   #5
1989 Mustang GT
I'm jus Wonderin bcuz I knw of ppl having bigger cam than me and having some bigger heads and just installed with no prob. Not even measuring.
Old October 7th, 2011, 02:45 PM   #6
fogged306's Avatar
89 GT
Just because they got away with doesn't make it a good idea. Yes the chances are you will be fine with those size valves and that cam, but you always check just to be sure. Deck height, valve reliefs, and compressed gasket thickness come into play checking PTV. Using the valve drop method is a pretty easy way of checking without using clay and having to take the heads off.
Old October 8th, 2011, 08:22 AM   #7
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
You'll be fine, do it
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old October 8th, 2011, 12:29 PM   #8
1989 Mustang GT
I'll be fine?@ stangbanger302 and I have to. About tht method @ fogged306
Old October 8th, 2011, 01:35 PM   #9
1992 Mustang LX
13.0 @ 105
Lol...sarcasm right there.
Old October 8th, 2011, 03:22 PM   #10
fogged306's Avatar
89 GT
Use a checking spring in place of your valve spring and make sure you have the correct length pushrod and your valve train geometry is set up correctly. Then go through the rotation of the crank 720 degrees to make sure the cam makes 1 full revolution with either a dial indicator on the rocker and keep pushing the valve down until it hits the piston when it's close to TDC, or feeler gauges inbetween the valve stem tip and rocker tip. If you have more than .080 on the intake valve and more than .100 on the exhaust through the full 720*, you're fine.
I'm not very good at explaining it but I'm sure if you google it you can find better instructions. PTV clearance "danger zone" isn't when the valve is at peak lift, it's when the valves are just about to open/close. You want more than those clearances I mentioned at these points. Feeler gauge is a pretty simple way of doing it and is how I measure. Just have to make sure you use a checking spring. Your regular valve spring will depress the plunger on a hydraulic lifter and give you false readings. It will also be impossible to push the valve down with your hand to measure PTV clearance anyway.
Old October 9th, 2011, 04:58 PM   #11
1989 Mustang GT
Thanks i will try this method if i dont use clay
Old December 3rd, 2011, 05:07 PM   #12
Modular is on a distinguished road
Either method will work just fine (clay or drop valve method).
Threads Similar to: Piston clearance???
piston clearance Mstngdtb 5.0 Mustangs 1 March 16th, 2010 04:31 AM
piston clearance? Applehead281 99-04 53 August 23rd, 2009 08:41 PM
Piston Clearance 95StangMX 5.0 Mustangs 11 January 10th, 2008 10:51 AM
Piston to Valve Clearance 94GTD1SC 5.0 Mustangs 6 April 11th, 2007 03:39 PM
Help With Piston to Valve Clearance 1WLDSTANG Classic Mustangs 2 November 12th, 2006 06:11 PM
