Backfire/Pop noise under acceleration
Old October 8th, 2011, 04:26 PM   #1
WildStang88's Avatar
1988
N/a
WildStang88 is on a distinguished road
Exclamation
Has anyone ever had this problem with their Mustang? I recently changed the stock distributor to a MSD Distributor, plugs and wires. When I start it up it hesitates for a few seconds, but when I get on it say 1500-2000 rpm it sputters and I hear this pop on the passenger side of the motor. After this pop / backfire is heard the car takes off as if a normal health engine would want to get up an go with no problem at all. I have the timing set at around 12 degrees. Could this be a spark plug wire issue not fully seated on the plug?
Old October 8th, 2011, 04:55 PM   #2
zinsavage123's Avatar
2001 Mustang GT
12.33@111.23mph
zinsavage123 will become famous soon enough
my 01 gt with o/d off letting off at at 100mph in the 1/4 makes popping noise too in the upper rpm's its normal though. I heard its letting off from the high rpm's in 3rd gear.
2001 Mustang GT - mods+pics in garage, tuned by matt@performance evolution
1996 Civic DX - my dd
Old October 8th, 2011, 05:08 PM   #3
1988
N/a
Its not multiple pops though. On take off when its running crappy it does just 1 pop and then mustang takes off like it should as if its a health engine.
Old October 8th, 2011, 05:13 PM   #4
1990 Mustang GT
Stevo077 is on a distinguished road
if its only when you take off after you first start your car, i imagine it has sometime to due with timing/air-fuel. Let your car warm up for 20-30 seconds then take off, see if it still does it.
1990 Mustang GT
Old October 8th, 2011, 05:26 PM   #5
1988
N/a
Could an intake leak cause this? Say for example if the car did warm up for 20-30 seconds. It doesnt seem to have this problem when the engine is at operating temp.
Old October 8th, 2011, 05:28 PM   #6
1990 Mustang GT
Im sure its possible, if you had a vacuum leak or something. how are your hoses? they still good, or all hard and cracked
1990 Mustang GT
Old October 8th, 2011, 05:57 PM   #7
1988
N/a
I did have to replace a hose that was hard and broken in places which used vacuum but that wasfor the climate controls. One thing I didnt mention was that at times it will idle higher than normal. It can get up to 1500-1700 rpm during idle. I just don't know if its related to the pop that occurs.
Old October 8th, 2011, 08:01 PM   #8
1988
N/a
I'm going to recheck my wires. I'm gonna make sure that the #4 is getting a good connection. The headers I have on there makes it hard to plug into the spark plug.
Old October 8th, 2011, 09:06 PM   #9
teamyamahablue08 is on a distinguished road
Sounds like an air/fuel or timing problem to me. The popping is unburnt fuel and could be a misfire, sounds to me like its running a little lean. I don't know much about the 5.0 but I assume that the fuel injected models were direct injection. If so, maybe try running some fuel injector cleaner through it. I've seen that clear up some lean conditions before and if it doesn't work it only costed like $6.
Old October 20th, 2011, 05:53 PM   #10
1988
N/a
Well the popping went away. I actually need to replace one of my oxygen sensors. I dont think that was the cause of it though. Someone I talked to was telling me that the computer had to relearn the fuel curve / pulse after I replaced my exhaust manifold with bbk equal length shortys. Anyone know if thats true?
1988 Mustang GT, Grey, BBK CAI, MSD Distributor and Wires, BBK Equal Length Shorty Headers, BBK O/R X-Pipe, Flowermaster Super 44's, 15x8 275/50/15 Nitto's-Rear, 15x5.5 155/80/15's BFG's-Front
Threads Similar to: Backfire/Pop noise under acceleration
acceleration and decceleration noise!!! Bullitt73 5.0 Mustangs 6 October 27th, 2010 10:34 PM
Squeeking Noise With Acceleration mcqueen V6 Mustangs 3 October 30th, 2009 10:43 AM
backfire mikestang 99-04 6 June 24th, 2009 07:07 PM
Boy did this backfire!!!!!!!!!!!! 87FloridaGT The Clubhouse 5 March 19th, 2009 05:34 PM
Backfire Dragondj11 V6 Mustangs 5 January 19th, 2009 08:18 PM
