Low oil pressure
Old October 10th, 2011, 12:38 PM   #1
dirty_d is on a distinguished road
Low oil pressure
while running cold at idle I have 50psi, after its up to operating temperature I'm down to 15-20psi at idle and about 30psi at 2000rpm. Just put in fresh 10w-40, no difference. How much cause for concern is this? I'm guessing the crank/rod bearings are worn and need replacing?
Old October 10th, 2011, 02:18 PM   #2
1990 Mustang GT
Stevo077 is on a distinguished road
Assuming the gauge is functioning correctly, low oil pressure is almost always caused by worn bearings. As the gaps between bearings and the other components widen more oil leaks out and the pressure drops. Sometimes a high volume oil pump can be added to help "get by" because it will pump enough that oil will still go everywhere it needs to...but that is just a band-aid fix. Eventually you'll need to rebuild the engine.
1990 Mustang GT
Old October 10th, 2011, 04:14 PM   #3
Proud American
MustangMatt96GT's Avatar
That oil pressure looks fine to me! Start getting worried when you are getting less than 10 psi per 1000 rpm
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old October 10th, 2011, 04:22 PM   #4
1990 Mustang GT
Idk it seems kinda low to me. I have 30-40 at idle and about 70-75 at WOT, when my stang was stock it still ran 30 at idle and about 60 at WOT
1990 Mustang GT
Old October 10th, 2011, 04:44 PM   #5
Proud American
Every motor is different... The motor in have in my car now, I build with looser tolerances I have similar numbers to him. 10 psi per 1000 rpm is the industry standard.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old October 10th, 2011, 07:03 PM   #6
Ok, that's what I figured, it still runs really smooth. Maybe this winter I can get an engine lift and do it. It really sucks not having a garage though.
Old October 10th, 2011, 07:39 PM   #7
fogged306's Avatar
89 GT
I wouldn't worry about that either. I did the same thing as Matt and my car runs about 15psi hot at idle. Only have about 700 miles on this engine, and I'm not worried in the slightest. I'd leave it be if it was my car.
Threads Similar to: Low oil pressure
What should oil pressure and fuel pressure be stevo306stang 99-04 2 March 28th, 2011 09:15 PM
New Oil Pressure Gae, New Pressure Readings 99GT35thLE 99-04 2 March 18th, 2011 09:13 PM
Oil pressure tap in rdspins89 2005 - 2010 5 March 1st, 2011 03:00 PM
oil pressure rainier446 99-04 7 March 26th, 2008 10:21 AM
