N/a
347 rotating assembly with what cylinder heads
If you guys had to chose between which heads to run with the kit below, which heads would you guys go with? I'm kinda interested to see why you would chose the heads. Better air flow? Works well with the kit? High rpm range?
SCAT Engine Components 1-45355BE - Scat Engine Rotating Assemblies - Overview - SummitRacing.com |
89 GT
If this is a street car, I would look at a different piston for that kit. 16.5 dome on a 3.4" stroke will give you a pretty high compression ratio. Even with a 72cc chamber you'll still be around 12:1-ish.
1989 Black LX---Turbo
Check out the kit below. Its all forged w/ H-beam rods. Flat top pistons for a mid 10:1 compression. This kit with a AFR 185 or Trick Flow FAC 190 head and something like a Comp XE274HR cam would make a very nice street motor. (if you're looking to spend less on a rotating ass. the cast version can be had for about $500 less)
10660-PS-F347 - Ford 347 Flat Top -4.0cc Pro Street Engine Kit
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
Threads Similar to: 347 rotating assembly with what cylinder heads
| rotating assembly help? | roosgt! | 99-04 | 3 | September 10th, 2011 12:44 PM |
| Rotating Assembly | andres0286 | 99-04 | 15 | August 4th, 2010 09:24 AM |
| which rotating assembly should i get? | 88Saleen | 5.0 Mustangs | 16 | December 6th, 2009 01:14 PM |
| Rotating Assembly on an 03' GT | hubba076 | 99-04 | 1 | May 16th, 2007 02:34 AM |
