#21 |
1991 Ford Mustang GT
Aw that sucks lol. If I didn't have a garage to work in I'd never even lift the hood. Lol every thing would take me' 10 times longer to do. I feel your pain
#22 |
talk about a pain in the ass. I had to unbolt the headers to even get plug #4 in the threads. I needed to unbolt the other side also to get the trimmed spark plug socket on #7. And after all that there is about 1/16" between the #4 terminal and the header tube. You either need to dent in the header tube or use a shorty plug on #7. I might just tear the boot off a wire, wrap the metal around it and insulate it somehow. If you want a tool that would be a lot better than what i used just get a deepwell 5/8" socket and use a cut off wheel to cut it so its just long enough to grab a fully seated plug and stick far out enough to be attached to some kinda handle. make 2 cuts down the length to make it like an open ended wrench then weld a handle at an angle to it. No guarantee you'd have room to be able to turn it far enough without it hitting something though.
#23 |
1991 gt vert
^^^^^^this tells me i'm shoping for new headers lol!
#24 |
Yea I was gonna say just save yourself the aggravation and get the right headers, lol.
#25 |
I got it all together yesterday. I found out a 5.0 HO can run on a 1-8-4-5-6-2-7-3 firing order, lol. A quick CW/CCW switcharoo fixed that problem. I still have a problem with the #4 plug though, I tried temporarily just globbing it up with rtv to insulate it from the headers, but its still misfiring on that cylinder. I've also bot a pretty bad exhaust leak. I think during all that spark plug madness I tore part of a gasket off. Anyone got any gt40p headers for sale? lol
#26 |
The ford racing gt40p shorty headers are on the way
#27 |
1982 GT t-top
no proof of purchase
I have bbk longtubes on my car with p heads and they fit fine with 90* plug boots and regular spark plugs. I did have to make a spark plug tool tho
#28 |
Smirnoff, where did you have fitment issues? I just used a regular spark plug socket for all 8 with my P's and BBK longtubes, there was only one where the ratchet wouldn't fit on the socket so i had to turn the socket with a wrench, was no big deal
#29 |
1982 GT t-top
I had issues with 5 and 6, I couldn't get a regular spark plug socket on them
#30 |
The new headers came in the mail today. I installed them out in the the dark with a flashlight in my mouth, lol. All I can say is holy shit what a difference, the gt40ps and 1.7 rockers are giving a very noticeable boost in power, especially when 2 of the plug boots aren't melted and shorting to the headers, lol. I do have an exhaust leak on the left header. For some reason the nuts on the ball and socket joint reach the end of the threads before the joint is sealed. Hopefully a few washers under the nuts will fix the problem. The car also sounds a lot more mean, at idle too, really loppy. I'm not sure if that's from the 1.7 rockers or what.
I'm also hearing a weird sound. kinda metallic but not really in a bad way. Is that just what roller rockers sound like? |
#31 |
1991 gt vert
how much where the frpp headers?
#32 |
$240 from latemodelrestoration.com, the lowest I could find.
Threads Similar to: GT40P swap
| GT40P head/cam swap issue | steve86gt | 5.0 Mustangs | 1 | August 2nd, 2010 06:10 PM |
| gt40p cam help! | Reefa92 | 5.0 Mustangs | 2 | July 15th, 2010 06:51 PM |
| 89 Lx Gt40p | stangage | 5.0 Mustangs | 7 | September 14th, 2009 01:55 AM |
| gt40p Q's | JBIGBOOTSY | 5.0 Mustangs | 12 | February 18th, 2008 01:37 AM |
| GT40p ? | stang94 | 5.0 Mustangs | 6 | December 7th, 2006 01:41 PM |
