Tranny leaking after driveshaft snapped
Old October 11th, 2011, 04:27 AM   #1
1986 ford mustang gt 351w
86gt351w is on a distinguished road
Question
Well I snapped the driveshaft when I slammed second, I stopped the car real quick and the only damage was 2 small dents in my mufflers, anyways I ordered a new aluminum driveshaft, changed the fluid, and drove it, well when I parked it i got under the car to check everything over and noticed the trans was leaking, so I cleaned it off real good and went for another drive to try and spot the leak, it appears it's coming from the top of the tranny between the shifter and bellhousing?? It doesn't leak much only a couple drips after each ride, but it only leaks when i drive it, it's a tremec trans that is fairly new I believe it's a 3350 it was installed a few years ago but car wasn't driven very much, what's weird is it didn't leak before I snapped the driveshaft? And like I said when it snapped i wasnt moving fast? What should I do? Pull the trans and do some investigation, it looks like there is a top plate that it may be leaking from? Any way to get to it through the center console with shifter removed? Thanks guys
Old October 12th, 2011, 12:56 AM   #2
Well I decided I'm gonna pull the trans and get a better visual of the problem and get it sealed up, my question is this, it's an 86 gt with the tremec as I have mentioned, I need a few pointers to get me Started in the right direction, what should I do first etc. Also when reinstalling the trans is there anything I need to know if someone could briefly run me through the most simple way to do this I would appreciate it, like I said it would just be easier IMO to pull it and see what the issue is. Thanks
Old October 12th, 2011, 12:58 AM   #3
One more thing, is it easier to pull the bell housing with the trans or keep the bell housing bolted up?
Old October 12th, 2011, 02:21 AM   #4
95ish5.0
SSteady98's Avatar
1995 GT
Slow
SSteady98 is on a distinguished road
Send a message via MSN to SSteady98
Keep the housing bolted up. you usually end up having to wiggle your way up to the very top bolts and only frustrate yourself more.
1995 Mustang GT
BBK Shorty Headers, H Pipe, CAI, UDP, 255lph Fuel Pump
Spec Stage 3 Clutch
FR500's all the way around
Cobra R Hood
*Want*
Gears, Cam, TW Heads, Turbo(Last)
Old October 17th, 2011, 11:12 PM   #5
Well I put the stang in storage and just pulled it back out, it sat for a couple of days and didn't leak much, I need help diagnosing this issue, it only leaks when u drive it, it doesn't leak much but enough, it started leaking after I snapped the driveshaft, wasn't moving fast so I know nothing cracked, it looks like its either leaking between the shifter and bellhousing where that plate is or between where the trans meets the bellhousing, how many seals are in that area? Thanks for the help
Threads Similar to: Tranny leaking after driveshaft snapped
Aluminum Driveshaft for 7.5 28 spline 4R70W Auto tranny Wataru V6 Mustangs 16 June 1st, 2010 07:05 AM
tranny leaking or my real main seal? Young Rand 5.0 Mustangs 16 May 6th, 2010 12:03 AM
Snapped some pics bandity2k00 Pictures 9 September 7th, 2009 12:11 PM
this sucks, leaking tranny fluid outlawzracing 5.0 Mustangs 16 July 8th, 2009 07:45 PM
i think i snapped a piston rod! billabongsmp V6 Mustangs 16 May 28th, 2009 07:40 PM
