COMPRESSION FOR TURBO MOTOR?
i'm getting a 363 dart built right now for my stang. i'm using 66mm single turbo for now. the heads i'm using are afr's 205's. with those heads the compression will stand at about 9:1. in future i'm planning to put another 66mm.. make it twin. is that a good compression for a turbo setup?? i'll be using the car on the street as well.
95 TURBOCHARGED COBRA 87 BLOW-THRU FOX |
#3 | |
I'm gonna go with 8.5:1 if I can ever scrounge up the money to build me a motor. The lower the compression, the more boost you can run. You can probably run that ratio okay but won't be able to run as much boost as a motor with 8.5:1 or lower. Tuning always plays a good role in that as well having an intercooler though.
#5 | |
9:1 is fine plus since he will be running twins soon he will have plenty of boost without running 18+ psi. With twins 12-14lbs will rip just fine..
Yeah, I was just pointing out that he'd be able to run "more" boost with a lower compression motor. But yeah, that should be fine depending on the tune.
89 GT
I would love to see some video of that at the track when you are done! That should move quite nicely as long as its tuned right like 8A_honda said.
How did that taste by the way :wink |
1988 Mustang LX Turbo
well if you havent built the motor yet, try to find the lowest comp. pistons possible and in your price range
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
#9 | |
9.1 is great for a turbo, if you go too low, you have to over boost to get the gains back from the lost compression. 9.1 with a motor built right will live a long time and make great number
RLY SRS
I have always been told that turbos like alittle more compression thena supercharger...Most of the people I know run 9:1 or 9.5:1 with their turbo set-ups...
#13 | ||
all motor
92 coupe
9.94@136.40
#14 | |
#15 | |||
Threads Similar to: COMPRESSION FOR TURBO MOTOR?
| 91 LX Motor And DIY Turbo Kit Build | wicked wendy | 5.0 Mustangs | 50 | November 19th, 2007 04:21 PM |
| building twin turbo cobra motor from scratch/Need HELP. | orangestang35th | 99-04 | 1 | July 24th, 2007 07:54 AM |
| is a 35psi turbo to much for 10.5 compression | 969800gt | 99-04 | 12 | March 21st, 2007 02:49 PM |
| 302,306,347,351-which motor would be best on boost (turbo) | 2ToneFox | 5.0 Mustangs | 5 | August 16th, 2006 09:36 PM |
| compression for new motor | Drgnracin72 | 99-04 | 20 | March 3rd, 2006 11:51 PM |
