need help asap!! o2 sensor question!
Old October 13th, 2011, 03:56 PM   #1
bl_rdrgz's Avatar
1991 Mustang GT 5.0
bl_rdrgz is on a distinguished road
I just need to know if my check engine light will come on if I disconnect my o2 sensors? And will it make any difference in performance. My check engine light came on because one of my o2 sensors fell out. Can I just take them out without any problem? Its a 91 ft auto thanks for any opinions!!
Old October 13th, 2011, 04:05 PM   #2
fogged306's Avatar
89 GT
Yea it'll make a difference and throw a check engine light on. You'll get shitty gas mileage and poor idle quality and part throttle response. At WOT you won't notice much of a difference because the O2's are ignored then, but they're a very critical part of the EEC's function and need to be there if it's a street car and you care about mileage at the least. .
Old October 13th, 2011, 04:16 PM   #3
bl_rdrgz's Avatar
1991 Mustang GT 5.0
Yes I do totally. I drive 85 miles highway daily I need good gas mileage. But my o2 sensor bung is now stripped. Any ideas of how to keep it in there without having to replace the bung
Old October 13th, 2011, 04:36 PM   #4
fogged306's Avatar
89 GT
Not anything that would make more sense than replacing the bung. That's an easy job and you can get o2 bungs at napa for like $2. Or even just get a nut that's the same thread size and pitch of the o2 sensor and weld that on. Just cut/drill the old one out and weld the new one on. Or even weld the old one up and drill a hole and weld a new one just behind or in front of the old one. You really don't want to do something sketchy that could leak because not only does an exhaust leak let exhaust out, it can let air in and screw up the o2 readings.
Old October 13th, 2011, 04:54 PM   #5
bl_rdrgz's Avatar
1991 Mustang GT 5.0
Alright thanks!
Threads Similar to: need help asap!! o2 sensor question!
Help asap Fuel rail pressure sensor!!!!!!!!!!!! stevo306stang 99-04 23 November 2nd, 2010 07:27 PM
Need Info on intalling speed sensor asap... Ford5.0 5.0 Mustangs 10 February 15th, 2010 12:25 AM
o2 sensor help needed asap 03SuperchargedGT 99-04 11 May 26th, 2009 02:02 AM
need help asap! IRS question Elder 4V / SVT 12 March 12th, 2008 05:45 PM
