1984 Cougar GT
Pushrod Help
im putting a motor together and i cant figure out what lenght of pushrod i need to use and i dont know what checker to buy either lol. i have a 306 with a B303 cam and E7 heads with GT40 springs and retainers. with the stock rockers.*for now*im pretty sure the block is a 94 but i couldnt find the vin on it, but thats what i was told. so any help would be great
Thanks
89 GT
The range you want for a pushrod checker is going to be in the low 6" range. The one I have for 302 blocks goes from 5.8 to 6.8. Stock is like 6.25 or 6.272 or something like that so you won't deviate from that much.
2001 gt
comp cams sells these jegs summit etc. the last three engines i did all ended up with comp cams 6.300 pushrods, when using your checker make sure you are using the spring your going to use. light springs lie becuase they dont deflect the valve train at all. secondly i would take an old lifter and weld the push rod cup too it so its like a solid. and if your using stock rockers dont expect to have the same lift as the cam card because they are'nt a true 1.6 ratio. you'll probably be .010-.025 short on max lift.
01 GT totaled, 97 cobra,95 GTS bracket racing crew member #8 |
1984 Cougar GT
okay thank you guys so much and yes the springs on there are the ones im using
89 GT
If you're using your normal valve spring just make sure to do what osa6637 mentioned and use solid lifter for checking. Some lifters you can take the retainer off, pull the cup, flip the plunger around and then put the cup and retainer back in and it will be a solid lifter. Some you can't do that with though because of the design.
1984 Cougar GT
im using ford roller lifters so would i still need a solid lifter?
89 GT
I'm fairly certain that the ford ones you can do like I mentioned and flip the plunger. I seem to remember that the Ford racing ones was one that I've flipped before but I can't say that 100% .I haven't done it in a while and I can't remember off the top of my head which ones you can and which ones you can't. Only way to tell is pull it apart. It will be very obvious if you can flip it or not.
1984 Cougar GT
i think ill just go to AZ and buy a cheap solid lifter. would that work
89 GT
Yep, that'll work too. Just make sure it's the same height from cup to tip as your hydraulic.
94 mustang gt
too slow to tell
Use one of your old litters there is a thread on hear about how to make a hydro lifter solid for checking pushrod length that's how I did mine it's free and it works
1989 Black LX---Turbo
Just take a stock hydro roller lifter and pull the guts out, flip the plunger over & put it back togather. The spring clip is a little tight, but will go back togather. I've been using the same set for years!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1984 Cougar GT
okay thankyou guys for all the help!
Threads Similar to: Pushrod Help
| Your advice on pushrod | LostSoul | 99-04 | 13 | January 16th, 2011 12:33 AM |
| pushrod length | StckFox | 5.0 Mustangs | 4 | August 16th, 2010 01:41 PM |
| Pushrod length | Burn'nRubber | 5.0 Mustangs | 5 | March 9th, 2009 07:23 PM |
| whoever knows the most about these pushrod cars....... help me | Drgnracin72 | 5.0 Mustangs | 28 | October 11th, 2008 09:39 AM |
| Bent Pushrod | Steves LX | 5.0 Mustangs | 1 | March 13th, 2007 12:48 AM |
