MSD replacement coil causing whining noise?
Old May 25th, 2007, 11:38 PM   #1
Redro is on a distinguished road
Hey Guys,
I just installed a new coil in my 5.0l LX . A MSD TFI coil which is a replacement for the stock coil. It puts out 148,000 volts...not sure what stock puts out though. Starting her up right after the install there is a high whining, ticking kind of sound. I went around the block and she pulls really nice, throttle response is good, idles good as well but the sound is quite evident. Has anybody experienced this or know why it is doing this. I had the same experience with a new Accel coil awhile back and returned it thinking it was defective. Any thoughts ....thanks.
Old May 26th, 2007, 12:52 AM   #2
tdf
tdf is on a distinguished road
If by chance your radio is on during the ride, the noise may be coming from the radio. Most coils need a condenser to filter the RF noise from interfering with the radio. If not that, then I have no clue. That voltage output seems very high. Are you sure it's not 48000?
Old May 26th, 2007, 12:56 AM   #3
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
Im running that same coil and dont have any noise. Not sure on that one.
Old May 26th, 2007, 12:59 AM   #4
fogged306's Avatar
89 GT
Haha, yea thats actually a good point. If you happen to have an aftermarket radio and it is on with the volume low sometimes you can hear a high pitched whine through the speakers when you do things like that.
Old May 26th, 2007, 01:22 PM   #5
I think I did misinterpret . It is actually 48,000 volts not 148,000.
Nonetheless the noise is still present. The stereo , running two amps is not affected. It plays without any interference. The noise is there instantly upon start-up.
Jam77 did you notice a difference in throttle response? Just curious. Will keep looking for answers. Thanks.
Old May 26th, 2007, 02:23 PM   #6
fogged306's Avatar
89 GT
Not to be a stickler here, but are you POSITIVE it isnt coming through the speakers? Now that i see you are running amps, it makes me think that is really the issue. I've seen that 100's of times, I've been installing stereos for about 10yrs. and its an extremely common problem. Actually put your ears to the speakers and listen to them with the radio on but volume at 0. rev the motor a little, does the whine go up in pitch with RPM's?
If you have done this already, completely disregard this.
Old May 26th, 2007, 02:47 PM   #7
The noise is there without the stereo even being on and it is definitely coming from the engine compartment..
Old May 26th, 2007, 06:24 PM   #8
1991 LX, 2003 SNK, 2007 S
11.3
cams-shelbycobra07 is on a distinguished road
Send a message via AIM to cams-shelbycobra07
my 0ld 2006 gt would howl and so would my dads old f-150 it had to do with the limited slip and the rear end going out. NOT sure if its the same on the old mustangs but just a suggestion
Old May 26th, 2007, 06:51 PM   #9
TurboLX's Avatar
1988 Mustang LX Turbo
then it wouldnt howl, and what is it with you, you post whoring to get your count up, because you've posting all kinds of wrong info...
i say call MSD themselves and see what they can do for you
Old May 26th, 2007, 07:11 PM   #10
SALIV8's Avatar
SALIV8 is on a distinguished road
msd sends invisible blowers now with their coils. Its just boostin.
hahaha, sorry, but i had to.
Old May 26th, 2007, 08:42 PM   #11
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
i have a rich daddy and he bought me a new 2007 shelby cuz i didnt like the smell of my 2006 and i have no clue what the difference is from rearends to coils....
im sorry that wasnt meant to be a direct attack on you man...
i had to just like saliv8
Old May 27th, 2007, 03:23 PM   #12
The limited slip diff thing has no relation to my issue at all..
I have sent MSD tech a mail ...hopefully they can shed some light on this.
Thanks for the suggestions...
1992 Mustang LX
Old May 28th, 2007, 01:03 AM   #13
Racinjason81 is on a distinguished road
My MSD TFI coil does it to ,It seems to be a common thing with these
coils .
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old May 29th, 2007, 10:32 PM   #14
Hey Jason,
At least someone else is experiencing the same problem. What have you done to remedy it. Does your car run fine with the noise. Also do you notice an increase in throttle response. I have not heard back from MSD yet. Might have to give them a call. Will post their reply.
Old May 30th, 2007, 09:54 PM   #15
Just got a reply from MSD Tech ...He says, the noise is normal with the MSD coil. This is caused by the frequency
in which the MSD coil is operating at. His words exactly.
Threads Similar to: MSD replacement coil causing whining noise?
Car Whining 40thANVGT 99-04 4 August 12th, 2007 03:12 PM
whining noise... El_Cangri V6 Mustangs 63 May 27th, 2007 11:56 AM
2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec ozan169 2005 - 2010 4 February 7th, 2007 10:03 PM
Need Answer (Whining Noise) Kope V6 Mustangs 8 December 6th, 2006 08:45 PM
coil pack to coil on plug conversion mustang_montana 96-98 6 July 24th, 2006 02:32 PM
