!!!MAJOR CLUTCH PROBLEMS!!! PLZ HELP!!!!
OK i own a 88 GT and recently installed a stage 2 clutch from act and while doing so i also put in a lighter flywheel. As soon as i installed the new clutch my old cable started giving me trouble so i replaced it. The same day my new cable either slipped or stretched and it was doing the same thing again... ( cant get into reverse *grindage* and it is very stiff to shift gears also i get a rattle when i give it a little gas but not at an idle.) I replaced the cable again and this time i replaced the fork too and once again it worked fine for a day and then back to the same old shit.. This has cost me over 2 grand in parts and labour already and i cant afford to keep putting it in the shop.. anyone got a solution?!! PLZ HELP M!!
not adjusting it right? you did put in an adjuster right?
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
Try adjusting the cable. Try to pull the clutch up with your foot and listen for a click. If this doesn't work, put a little pressure on the clutch pedal with one hand then hold the quadrant with the other. While holding the quadrant pull up on the clutch pedal. Just go one click at a time and check the clutch between clicks to see if it will go into gear.
do you still have the stock plastic clutch quadrant?if you do that may be your problem right there.high mileage and stiff pressure plates speed up failure
I agree, sounds like it is time for an aluminum quadrant and firewall adjuster.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
had the same problem...you need look up how to re-set the adjuster or else your going to keep streting the cable, i just bought an after market clutch cable that adjust by the bell-housing its nice cause you can set when the clutch starts to grab...
1987 ford mustang gt
well see when shes done
2 grand damn you need to start doing the work yourself.
98 Cobra
1990 LX hatch
sometimes the throw out bearing, fork and input shaft can rattle in neutral. If the rattle stops when the clutch is pressed in, then it would be either the inputshaft ot throw out bearing.
1988 lx
9.68@142
sounds like u have an aluminum bearing retainer and its worn out too.. that will cause hard shifting and noise.
1994 Mustang GT
I would make the shop fix it for free they installed it wrong
1994 Mustang GT HCI N2O yada yada yada http://www.cardomain.com/id/bigshirtlesspete |
98 Cobra
OLD post
1988 lx t-top
i had the same problem when i swaped the v8 in so i just cut a new clutch quadrant out of a piece of aluminum and used washers to adjust it on the trans end of the cable
1982 GT t-top
no proof of purchase
damn i just bought an aluminum quadrant and firewall adjuster i never even thought about making my own
DUDE! I love your 79 cobra hood decal avatar!
we need a 4 eyed section ok back to your regularly scheduled thread.
1986 Mustang GT t-top time piece! |
Threads Similar to: !!!MAJOR CLUTCH PROBLEMS!!! PLZ HELP!!!!
| !!!MAJOR CLUTCH PROBLEMS!!! PLZ HELP!!!! | Hububula | 5.0 Mustangs | 3 | June 6th, 2007 10:30 PM |
| CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS | Hububula | 5.0 Mustangs | 3 | May 28th, 2007 10:08 AM |
| MAJOR TRANNY PROBLEMS! | Jeff99gt | 99-04 | 13 | May 9th, 2007 01:37 PM |
| Major Problems, Need Help | super240sx | 99-04 | 10 | October 30th, 2006 05:48 PM |
| Major engine problems, please help! | 03 R Code | 99-04 | 6 | August 25th, 2006 05:39 PM |
