Will AFR 185's fit on a stock bottom end???
Old October 15th, 2011, 08:00 PM   #1
OiDALE's Avatar
1991 Mustang GT
OiDALE is on a distinguished road
Will AFR 185's fit on a stock bottom end??? (PICS)
I found a really good deal on a pair of afr 185's that one needs very minor work but I just looked on AFR's website and they said that the 185's wil not fit a stock motor even with a stock cam without notching the pistons...Is that absolutley true??? I am not taking my motor apart nor out of the car if it is...I wanted to have them fixed and install them in a weekend.
Please help??? Should I buy them or pass them up...Man I really wanted some afr's...What set of heads are comparable and that will match my sytemax intake besides these without tearing into my low mileage bottom end?
Has everyone that run afr's been into the bottom end of there 302?
Old October 15th, 2011, 08:38 PM   #2
fogged306's Avatar
89 GT
You don't have to pull your bottom end apart to fly cut your pistons. You just need to mask off the area and make sure you clean all the shavings before you put the heads on.
Old October 15th, 2011, 09:01 PM   #3
OiDALE's Avatar
1991 Mustang GT
How is that cut done? Is there a machine that I can rent or is it grinded out? If so, how to make sure each cylinder is cut exactly and maintain the same weight?
Old October 15th, 2011, 09:21 PM   #4
fogged306's Avatar
89 GT
You remove the valve and the tool goes through the valve guide just like it's a valve. Then you install the piston and turn the cutter. Use a caliper with a depth measurement probe end on it to measure the depth of the cut. As long as they're all the same depth, then the same amount of weight has been removed from the piston and you don't have to worry about balance.
notching tool
Old October 15th, 2011, 10:55 PM   #5
OiDALE's Avatar
1991 Mustang GT
That pretty interesting but I think its a little more involved then what I want to get into...But, I really thank you for the info and your knowledge.
Old October 15th, 2011, 11:09 PM   #6
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
I bought the through the head piston cutter from the company below, and it works awsome!
AFR 165's will fit a stock bottom end.
Lindy Tools
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old October 15th, 2011, 11:39 PM   #7
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Don't waste money on afr165s. TW>AFR anyways.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old October 16th, 2011, 11:49 AM   #8
OiDALE's Avatar
1991 Mustang GT
You think the tw will work better with the holley sytemax and a stock bottom? Im also spraying at the moment but will go turbo...
Old October 16th, 2011, 11:55 AM   #9
I have TW 170's on a stock 89 HO short block with a Comp XE266HR(216/224 w/.544/.555 lift) I had over 100 thousands PTV clearance, but every engine varies, so check it anyway! (for what it is this engine runs awsome)
01 Ram Quad Cab
03 Grizzley 660
Old October 17th, 2011, 08:58 AM   #10
OiDALE's Avatar
1991 Mustang GT
HERES A LINK TO THE PICS WHICH ARE AT THE END: WILL NOT LET ME POST PICS HERE...
http://www.allfordmustangs.com/forum...ottom-end.html
Old October 17th, 2011, 09:07 AM   #11
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Yes. Especially with the stock bottom end. AFR makes a good head, but on a stock bore block the inline heads with a 2.02 valve suffer from shrouding of the intake valve. The valve relocation on the TWs unshrouds the intake valve, and gives better P to V clearance than an inline head.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 17th, 2011, 10:00 AM   #12
fogged306's Avatar
89 GT
Don't bother with those heads. Not worth it for $400. Look into TW's like ^ homo said.
Old October 17th, 2011, 10:35 AM   #13
OiDALE's Avatar
1991 Mustang GT
Thats what Im begining to think...I think I might pass, even if I were to fix them plus the cost to buy them, I would be close to 800 or so...Just to try to sell them at 1000 or even 900. Not worth the headache for 100/200 in profit if I even make a profit...I think I might just wait around for some twisted wedges. Thanks...
Old October 17th, 2011, 12:20 PM   #14
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Originally Posted by fogged306 View Post
^ homo said.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 17th, 2011, 11:50 PM   #15
EscortSportage's Avatar
1989 Mustang GT 5.0
Its so funny my buddy and i have been argueing whats a bette head
Tfs tw vs afr vs canfield vs wurl ve dart
Im for tfs tw (which he has and i want to buy em) he has the 170s i beleave but he wants afrs, cuz darts are too expensive
Id kill for his 170s tw. Take my scorpian rr and put em in. And sell my pro comps
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old October 21st, 2011, 09:07 PM   #16
OiDALE's Avatar
1991 Mustang GT
Yep, thats the way im going to go...I just need to find a set at a decent price...
Old October 24th, 2011, 03:55 PM   #17
e3sean's Avatar
1988 lx
9.68@142
if you can get the afr's for a good price have them fixed you could proly trade or sell them for enough to buy the tfs heads. and i agree TW all the way. i run a set of origional series t/w heads on my mustang 10.0 n/a on a 302 block. shiftyeyes
<font size=4><b>MILITARY CREW
Old October 27th, 2011, 08:04 AM   #18
The guy in the link below seems to run pretty good with AFR 165's!
NEW 11 second track times - Stock shortblock '94 Cobra - Ford Mustang Forums : Corral.net Mustang Forum
01 Ram Quad Cab
03 Grizzley 660
Threads Similar to: Will AFR 185's fit on a stock bottom end???
Max HP on a stock 3V bottom end? 06PONY 2005 - 2010 24 May 9th, 2011 03:11 PM
my stock bottom end/tranny CougarBullitt6801 99-04 13 November 20th, 2009 12:23 PM
How Much HP On Stock Bottom End 5litercobra 2.3 Mustangs 5 November 13th, 2007 02:55 PM
12s with stock bottom end? 95wip 94-95 8 April 16th, 2007 11:10 PM
How Much HP Can Stock GT Bottom End Take? Clutchmaster 99-04 14 March 22nd, 2007 03:58 PM
