Discussing underdrive pulleys on the way in the 5.0 Mustangs Forum. i ordered some mac underdrive pulleys...theyre the black ones nothin special...what kinda gains ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1991 mustang lx 5.0
14.5@92
underdrive pulleys on the way |
IT'S TURBO TIME
1990 Mustang LX Turbo
maybe a good 5hp
Put up, Shut up, Line Up And Get Beat Up!!! |
Top five questions about underdrive pulleys.
Just remember they are selling them though. http://www.marchperf.com/underdrive2.html
2007 Explorer Sport Trac, 292 HP, Stock 2002 Mustang GT |
i started to have eletrical problems after i got some years ago.
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion |
#5 | |
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller 13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock |
what is the 3g upgrade >?
#7 | |
1991 mustang lx 5.0
14.5@92
would it be defeating the purpose if i dont run the alternator pulley on it..would i still see some gains?
#9 | ||
Just to let everyone know, it is a really really good idea to put a fuse between the alternator and the solenoid if you are going to upgrade your alt wiring. Autozone sells 175 AMP fuses cheap. Here is the reason, the sock wiring has a fusable link that is designed to fail, but if you replace this with a 4 ga wire you can have some problems. If your alternator diodes go bad and result in a ground to the alt case you are suddenly connecting the positive side of your battery directly to ground with no fuse or fusable link. This could easily result in a fire or small battery explosion. It can happen, that is why a fusable link is designed into the stock wiring. |
#10 | |||
89 GT
Luckily the adjuster was an idiot and blamed the problem on the hi-amp alt. we installed at the same time and the kid got to keep his job. |
Yeah, I bought my 3g upgrade from a reputable alternator company. I asked them about needing a fuse or fusable link.
They actually told me there was no purpose for it. I asked what if the wire grounded out. They said that "never happens". Good thing I did some research, before the installation.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph 88 GT 11.4 @ 118
1986 Mustang GT
I wouldnt worry about the charging I just put the march set on my 86 gt and no difference in charging they have been on for almost a month.
They wont make a difference unless you have a huge stereo system that you need to have at a high volume at idle |
i know a guy who got a set and then 5 years later, bam, herpes.
j/k |
89 GT
I recently purchased a 89 5.0 that has underdrive pulleys and I hate how they slow the alternator making my lights dim. Would I be able to replace just the alternator pulley to fix this or would I have to replace all three pulleys?
you can put the stock alt pulley on there and keep the other two on there...Many people do that....I have no charging problems though.
393 dropping in a foxbody near you, very very soonMilitary Crew E-3 Combat Engineer |
Yes, puting a fuse inline in that 4 ga wire is a very good idea. That is how I have mine setup, I forgot to mention it in my previous post. Good catch guys.
1986 Mustang GT
I dont have any problems with dimming lights
I dont know why everyone does ive never personaly met anyone that had problems with them
#19 | |
1991 mustang lx 5.0
14.5@92
finally got them in on friday and started to put them on saturday and the pulley on the alt. would not come off so im takin it somewhere today and gettin it took off and finishing up the install
Threads Similar to: underdrive pulleys on the way
| BBk underdrive pulleys | 03Gtmustang | 99-04 | 6 | September 26th, 2007 03:46 PM |
| when you buy underdrive pulleys | matfernan1 | 99-04 | 21 | September 26th, 2007 01:55 AM |
| Underdrive Pulleys | justinsstang | V6 Mustangs | 6 | February 24th, 2007 04:14 AM |
| Underdrive Pulleys | 97stanger | V6 Mustangs | 26 | February 22nd, 2007 11:29 PM |
| Underdrive Pulleys | jerb43 | 96-98 | 5 | October 24th, 2006 12:05 PM |
