1984 Cougar GT
cam gear?
What kind of gear should on my dizzy if I'm running a b303 cam does it matter if its brass or steal? I don't wanna eat up my cam or anything and can I change the gear or do I need a whole new dizzy. Any help would be great thanks
1989 Black LX---Turbo
General rule: flat tappet=cast gear, hydro roller=steel gear, solid roller=brass gear.
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1984 Cougar GT
well okay. so im gunna have to run a brass gear now can i change the gear out??
Your B303 is a solid roller cam??
1995 Mustang GT
B Ford cam is roller. You need a steel gear.
89 GT
Bronze is for billet cores. You use a steel gear if you have a SADI roller cam, solid or hydraulic. Letter cams are SADI core rollers, so use a steel gear.
1989 LX hatch
15 and change
is the stock gear steal?
1987 Buick Grand National 1989 Mustang LX 5.0 Both BLACK
1991 Ford Mustang GT
^^^ i think its cast steal
Threads Similar to: cam gear?
| Rear Gear Swap Pricing and Gear Oil | TStang | 2005 - 2010 | 9 | August 17th, 2010 06:09 PM |
| Gear to gear on a Mach | stangless24 | 4V / SVT | 25 | June 11th, 2008 06:24 PM |
| Cam gear and camshaft position sensor gear... | 99v6stang | V6 Mustangs | 17 | January 17th, 2008 02:00 PM |
| 4.30 Gear to much gear for street use/daily driver? | Bigb2000GT | 99-04 | 10 | March 28th, 2007 05:22 PM |
