Smokin!! Need help
Old October 17th, 2011, 06:56 PM   #1
1994 Mustang GT 5.0
94-5.0 is on a distinguished road
Smokin!! Need help
So my 94 mustang gt has been smoking and burning oil like crazy (about a quart a week). I know its something to do with the pistons and valves and stuff like that. But I was just wondering if I stroke it to a 347 would that fix the problem?
ALL HELP IS APPRECIATED. THANKS
94 5.0
Old October 17th, 2011, 11:16 PM   #2
1995 Mustang GT
Bubba95SN is on a distinguished road
That would be a rebuild.
Old October 17th, 2011, 11:27 PM   #3
1994 Mustang GT 5.0
Okay
Is there any type of rebuild kit you recamend. One with pistons or without? And if with, What type?
Old October 18th, 2011, 09:13 AM   #4
fogged306's Avatar
89 GT
First you need to source the issue. If it's in your valve guides then rebuilding the bottom end won't do a thing for you. Do a compression check dry and then wet and then post up your results.
Old October 18th, 2011, 03:31 PM   #5
1994 Mustang GT 5.0
Whats the difference? I have done a Dry compression test and they were all around 125 (each within 5 pounds difference)
Old October 18th, 2011, 05:31 PM   #6
fogged306's Avatar
89 GT
You put a little oil in each cylinder and try the test again. If the reading goes up considerably (150-160 or so) then your rings are shot. If it stays right at 125 then it's worn valve guides most likely. You can also do a leakdown to pinpoint where you're oil is coming into the cylinder from.
Also make sure you put oil in and test each cylinder individually. Not sure if I made is sound like you put oil in all the cylinders at once and then try the test, just pour oil in and test one by one so the oil doesn't have a chance to seep past the rings before the test.
Old October 18th, 2011, 05:41 PM   #7
1994 Mustang GT 5.0
Okay. Ill do that on the next sunny day we get here.
Are there any types of rings or valve guides you recamend?
Old October 18th, 2011, 05:57 PM   #8
fogged306's Avatar
89 GT
Unless you've got plans to make decent power, stock replacement stuff should be just fine. I wouldn't go ordering rings yet though. If the wet test tells you the bottom end is the culprit then you need to pull the heads and check the condition of the cylinder walls first.
Threads Similar to: Smokin!! Need help
What's this guy smokin'? RZNCAIN The Clubhouse 43 October 30th, 2010 07:09 AM
smokin stage2ROUSH 2005 - 2010 16 January 6th, 2009 12:39 PM
Termi Smokin Z06 97GT4.6 Videos 35 March 7th, 2008 11:55 PM
Smokin' Performance RALVAREZ26 Southwest 0 November 28th, 2007 07:31 PM
