70 mm TB??? Looking for opinions...
Old October 17th, 2011, 07:03 PM   #1
OZ_872's Avatar
OZ_872 is on a distinguished road
My mods are as follows... Cold air, 76 mm MAF, Paxton SN93 around 8-9 psi, Explorer TB/upper/lower intake, GT40p heads, X303 cam, BBK 1 3/4 long tubes, BBK H pipe, 5 speed, 3.73 gears... I think that should cover it, wondering if finding a used 70 mm TB is going to be a worth while endevour?
Thanks
Old October 18th, 2011, 10:27 AM   #2
OiDALE's Avatar
1991 Mustang GT
OiDALE is on a distinguished road
It wont hurt...And gives you room to grow some more. You might feel a bit of a difference appose to the tb you have. Not sure the size of the stock explorer (It might be 70mm)I will Let someone else answer that...If it is then just stick with what you have unless your going for looks as there are many polished units that look pretty cool.
Old October 18th, 2011, 11:21 AM   #3
ryanw's Avatar
1991 Ford Mustang GT
What ever size you get just make sure the opening on the intake is the same size or bigger. Port match it,if have to.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 18th, 2011, 11:22 AM   #4
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
I would go for a 75mm since you already have the 76mm MAF. Like the guy above me has said, more room for future mods! You may not gain a whole lot from it but from my experiences more flow = more go.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old October 18th, 2011, 05:48 PM   #5
OZ_872's Avatar
stock explorer is 65mm, the opening on the upper intake measures out to around 67-68mm ish. The other thing i was contemplating about was that the outlet from the supercharger only measures approx. 69.85mm (2.75 in.)
Old October 18th, 2011, 05:55 PM   #6
fogged306's Avatar
89 GT
In your case, I don't really see that extra 5 mm doing you a whole lot. At least not enough to justify spending over $100.
Threads Similar to: 70 mm TB??? Looking for opinions...
opinions SS Ball3r 99-04 18 November 21st, 2010 05:13 PM
need opinions please!!! mustang95 5.0 5.0 Mustangs 4 September 27th, 2009 12:23 AM
opinions about this look on my car...please vote....or post your opinions.. turbot4 99-04 79 July 22nd, 2009 07:31 AM
opinions zinc02GT The Clubhouse 36 June 18th, 2008 03:35 PM
Opinions G.T. Rags The Clubhouse 13 June 16th, 2008 01:14 AM
