Fuel lines
Old October 18th, 2011, 12:20 AM   #1
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
Fuel lines
So i have a 91 lx and one of the fuel lines are leaking in front of the differential. i know its not safe and i need to get it fixed. instead of getting a whole new line for around 100 bucks could i get some line from napa or somewhere and splice it in.
also i cant see the leak , i think its a crack on the top side or something
Old October 18th, 2011, 12:23 AM   #2
uncut
LethalDosage's Avatar
2008 Mustang GT
LethalDosage is a jewel in the roughLethalDosage is a jewel in the roughLethalDosage is a jewel in the roughLethalDosage is a jewel in the rough
You might get more help in the modular mustangs section.
Idunno...just sayin
You probably can do a workaround, but how long that little fix will last? With fuel lines, cuz they're kinda important, I'd bite the bullet n get replacements.
| 2008 GT | Full MAC Exhaust | BAMA 93 Race Tune | 4.10's | Boss 338's | Ford Race Suspension | Airaid CAI | BBK 62mm TB | HURST Short Throw |
Too weird to live, and too rare to die.
Old October 18th, 2011, 02:48 AM   #3
Glorious PC gaming master race
graystang01's Avatar
2003 Audi A4
boats & hoes
graystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to behold
Send a message via AIM to graystang01 Send a message via MSN to graystang01
Fuel line delete kit. Save some weight.
MILITARY CREW - USAF E-4
Originally Posted by thrasher! View Post
You know you can do better. I'm not going to just let you settle for every little Asian that glances her squinty little eyes your way.
Originally Posted by mr.burton View Post
I was on my knees for 2 hours today
Elmo187 loves 8==D
Old October 18th, 2011, 09:05 AM   #4
fogged306's Avatar
89 GT
Yea you can do that no problem. Just make sure you get fuel line rated for high pressure injection systems and the correct hose clamps. And when you cut the line make sure you don't squish it flat. If you use any form of cutting tool like tin snips or sidecutters, it will crimp the line when it cuts it and you'll have to make it round again.
Old October 18th, 2011, 09:50 PM   #5
brandon444's Avatar
91 Mustang LX 5.0
so whats the best way to splice it in and what kind of line do should i use
Old October 19th, 2011, 03:55 AM   #6
fogged306's Avatar
89 GT
High pressure fuel injection line, you can get it at any parts store by the foot. Supply is 5/16" and return is 1/4"... I found a tiny pipe cutter that works a while ago but I can't remember where I picked that up. If you can find one, that's the best way I've found. You can also cut it with some good sidecutters and then use a hacksaw to cut off the end that crimped. Or you can use the sidecutters and then pliers to squish the crimped end back to semi-round and gently hammer a punch in the line to get it back to its round shape. I've done all 3. Pipe cutter is by far the easiest if you can find one that is short enough and small enough to fit the lines. Obviously you've got to do some bending to use the pipe cutter but it definitely saves a lot of time.
Threads Similar to: Fuel lines
Fuel lines jesusm3 5.0 Mustangs 8 March 19th, 2011 04:09 AM
fuel lines running to the fuel rail RoushRacing99 2.3 Mustangs 1 March 9th, 2011 10:00 PM
how to run fuel lines with aftermarket fuel regulator bretts95gt General Tech 0 February 18th, 2011 07:58 PM
why do i have 3 fuel lines? Bushy 5.0 Mustangs 6 February 18th, 2010 01:19 PM
Fuel lines JBIGBOOTSY 5.0 Mustangs 2 August 31st, 2007 07:10 PM
