Engine bay wire hiding
Old October 18th, 2011, 01:30 PM   #1
MIGHTYJO3YOUNG's Avatar
1992 mustang Lx
13.4@ 106
MIGHTYJO3YOUNG is on a distinguished road
I have been hiding the wires and got everything done, then I wanted to hide the vacuum tree in the fender since I have it off at the moment. My cruise control didn't work all of the sudden one day while I was in the middle of using it. Just stopped for no reason. Well, I think I have found the reason. I disconnected all of the vacuum lines and they all have oil in them. The tube running from the tree to the cruise canister had a ton blocking the little separator that puts the two lines together. It took a little effort to blow it out, but I think this is deff my problem with the cruise control. I'm thinking I really need to invest in a oil catcher from my pvc. I remember the last time I took the upper off there was an odd amount of oil in it. Other than that the bay looks AWESOME! other than the holes that are all over now because I have the engine in still and cant weld them. Maybe one day! I'll post pics later. Just thought it was an interesting cause for the cruise control to stop working.
1992 5.0 lx_soon to be powered by a m122 GT500 supercharger
Old October 18th, 2011, 03:15 PM   #2
1992 mustang Lx
13.4@ 106
I also posted up a while ago about having a bad idle surge problem on startup. After rerouting all my wires and drilling new grounds I have no idle surge at all. This problem was fixed before messing with vacuum lines, and there were no leaks with vacuum. I had torn the upper off searching for the problem, and all this time I think it was bad grounds.
Old October 18th, 2011, 11:49 PM   #3
ryanw's Avatar
1991 Ford Mustang GT
Glad to hear the problems been fixed. Did you have to splice a lot of wires and drill a bunch more holes to re rout them through the fenders ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 19th, 2011, 01:35 AM   #4
1992 mustang Lx
13.4@ 106
ehh unfortunately cruise is still out. There are other things I will look into to fix that. As far as the wire re-routing goes I didn't have to splice very much. Only once actually for the wires that go to the brake booster fluid tank. Everything fit in the two holes behind each strut tower without having to make them any bigger. Only drilled to remount sensors in different locations. I also had to buy some wire to replace the starter cables to the solenoid so they would reach. Soldered up nice and tight. I am very pleased, although it took a lot of time, its worth the clean look.
here are some pics of the process, and the finished product.
Old October 19th, 2011, 01:37 AM   #5
fogged306's Avatar
89 GT
When I did mine, I only drilled one hole for my engine harness, and that's only because I wanted it to come out directly behind the engine so you couldn't see it. The way I did mine, there was quite a bit of splicing, but you could get away with a lot less than I did. Not much actually had to be extended at all.
Old October 19th, 2011, 02:04 AM   #6
1992 mustang Lx
13.4@ 106
did you run your harness behind the dash?
Old October 19th, 2011, 03:40 AM   #7
fogged306's Avatar
89 GT
Yea, the whole engine harness runs along the inside of the firewall. I cut the salt and pepper shakers out and just made it into one single harness coming out behind the intake.
Threads Similar to: Engine bay wire hiding
Hiding Stuff in the engine bay r.i.pchevy 5.0 Mustangs 6 January 21st, 2011 03:56 PM
Is there a wire that outputs a constant 12 volt when the engine is on? asiansensation78 99-04 8 September 10th, 2010 11:01 PM
Help hiding sub wires.. whyxitx V6 Mustangs 6 August 1st, 2010 11:20 AM
Ground Wire Gauge.. Same Size as Power Wire or No? warrior86 Audio/Video 4 January 30th, 2010 06:41 PM
Pass Wire from Engine to cabin Safi The Clubhouse 9 March 13th, 2009 09:11 PM
