94 mustang,88 mustang
n/a
93 5.0 not getting any spark
I wasn't getting any spark so I replaced my dizzy and module but am still not getting spark,what else can be my problem.
2011 Malibu LTZ (Daily driver) 94 Mustang GT (Weekend toy) 88 Mustang GT (Track car)
1992 Mustang GT
dont know yet
Did you tighten everything down inside of the dizzy seems there was someone on here not to long ago that installed a new dizzy and was getting no spark but something in the dizzy wasn't all the way tight. If that isn't the case make sure the dizzy is spinning.
Sent from my Autoguide iPhone app
______________ Mods: Paxton Novi 2000 @10psi 3.73 gears 255lph fuel pump Lucas 42# injectors Trick Flow 75mm upper intake Trick Flow 75mm throttle body Diablo "MAFia" Dyno tuned by Force Fed performance Sacramento Ca |
n/a
Thanks,yeah I double checked everything and also made sure my dizzy is spinning. Am getting spark from the coil but not from the dizzy could it be my rotor or cap.
#4 | |
1992 Mustang GT
dont know yet
Sent from my Autoguide iPhone app Sent from my Autoguide iPhone app
89 GT
If you're getting spark at the coil then it's either the cap, rotor, or wire going from the coil to the dizzy. Does the spark look strong (blueish) at the coil?
n/a
Yeah the spark looks pretty strong at the coil, am gonna go ahead and make sure everything is tight and if it still fails I'm gonna start with rotor then cap.
89 GT
Easy thing to start with is the coil wire, unless that's what you're using to test the coil itself. If that's the case and you're getting good spark at the end of that wire, then yea cap and rotor are pretty much the only things left.
Threads Similar to: 93 5.0 not getting any spark
| Nology HotWires Spark Plug Wires. More Hp More power 300% more spark..?? | 4U2C | V6 Mustangs | 4 | July 1st, 2011 04:40 PM |
| No spark??? | 94mustang | 5.0 Mustangs | 1 | February 21st, 2011 05:12 AM |
| Demon Coil, IX Perormance Spark plugs,Spark Plug wires? | v6 stunna | V6 Mustangs | 15 | February 9th, 2011 01:31 AM |
| No spark :( | 707Stang | 5.0 Mustangs | 6 | June 24th, 2009 01:42 PM |
| NEED HELP Please. NO SPARK AGAIN | noyz25 | 5.0 Mustangs | 9 | August 15th, 2007 06:08 PM |
