Back Pressure & Most HP
Old October 18th, 2011, 10:10 PM   #1
1994 Mustang GT 5.0
94-5.0 is on a distinguished road
What type and series of mufflers gives you the best back pressure and the most HP??
I have Shorty headers to 3inch pipes to Flowmaster 50s. no cat or anything (true duals)
What should i do to get the most HP gain out of my 5.0
Old October 18th, 2011, 11:07 PM   #2
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Back pressure is a myth. You want the best scavenging possible.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old October 18th, 2011, 11:09 PM   #3
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Sent from my HTC Wildfire using AutoGuide App
Old October 20th, 2011, 02:07 PM   #4
Authorized Vendor
flowmann is on a distinguished road
94-5.0 – Actually back pressure isn’t a myth…back pressure does exist. Needing back pressure to run well is a common urban legend or misconception. Many muffler shops will install a new 3-inch diameter system on a car with 350 HP. It ran great with the old 2.5-inch system and now with the 3-inch system it lost power and torque. The assumption is that it needs the smaller system to create back pressure. That’s not the case. The new 3-inch system was too big and reduced velocity. Velocity is what helps the exhaust flow out of the exhaust pipe faster and that’s what makes power. If the engine is blowing into a huge pipe, the velocity drops considerable. If you installed a 2-inch diameter exhaust on the same engine, the exhaust couldn’t get out of the system fast enough…causing back pressure.
The key is to get the right size tubing (and muffler size and construction) to promote velocity…not back pressure. This is why so many street and race cars run Flowmaster chambered and non-chambered mufflers. Their internal designs manipulate exhaust pulses to increase velocity. The science, technology, dynos, and track time prove that our mufflers work. This is also why our mufflers need to be installed in one direction. Mufflers that install either direction are only slowing the exhaust down without using science to promote velocity.
What other modifications have you done to your Mustang? You may have the best exhaust system for your car already.
Flowmaster Mufflers
Toll Free Technical Support: 1-800-544-4761
www.flowmastermufflers.com
www.facebook.com/FlowmasterMufflersINC
Old October 20th, 2011, 02:33 PM   #5
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
I'm with flowman^
Unless you are pushing some heavy mods, 2.5inch is pretty ideal. Hell, the stock 2.25inch is great up until about 280hp or so.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old October 20th, 2011, 02:36 PM   #6
1967 Mustang 302
67Sleeper is on a distinguished road
nice info there
Old October 20th, 2011, 04:43 PM   #7
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I'm pretty sure it was obvious what backprssure is a myth meant.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 20th, 2011, 04:48 PM   #8
fogged306's Avatar
89 GT
lol
Old October 20th, 2011, 05:12 PM   #9
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Not contradicting what anyone's said so far, but I thought that I had read somewhere that the backpressure that's important for torque production is established by the size of the exhaust manifold collector and/or primary exhaust tubes. I'm extrapolating that that's why Tri-Ys have a different torque curve than 4->1s.
O o
/Ż/______________________
\_\
Old October 20th, 2011, 05:19 PM   #10
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
See post #2.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 20th, 2011, 05:23 PM   #11
fogged306's Avatar
89 GT
For further explanation read this.
Old October 20th, 2011, 05:25 PM   #12
1994 Mustang GT 5.0
I dont have many mods. so i think after i get the smoking fixed ill change to 2 1/2 inch pipes
Old October 21st, 2011, 02:37 PM   #13
Authorized Vendor
69Fastback - We knew what you meant. We just wanted to clarify for other members. You never know how new some members are to the hobby.
By the way, how big are the tires on the back of your sweet ’69 Fastback?
Flowmaster Mufflers
Old October 21st, 2011, 03:45 PM   #14
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
The street tires are 275/60/15. The ones you can see on the prostars in the sig pic were 275/55/15 because it was a gutless turd when I bought those, but now it has a 28X10.5 ET Drag on those.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Threads Similar to: Back Pressure & Most HP
loss of back-pressure stopher50 2005 - 2010 V6 8 April 19th, 2011 09:35 AM
Back Pressure-Good, Bad?? F8L GT 99-04 16 December 7th, 2009 01:52 AM
Back pressure? DickH 99-04 24 November 14th, 2008 08:48 AM
A Question Of Back Pressure luke 200 5.0 Mustangs 8 November 16th, 2006 07:44 AM
loss of back pressure cobralini General Tech 4 May 16th, 2006 06:42 PM
