miss firing
Old May 26th, 2007, 09:04 PM   #1
hopper is on a distinguished road
miss firing
i have been having major prob with this dam car... someone please help... 86 5.0 fuel injected, speed density,, the cars starts great and rund great for about 500 yrds. Then under load at lower rpm i get miss and popping or backfiring through the exhaust,,,, if i cruise it runs great at idel it runs great just under load it acts shitty..
any suggestions
Old May 26th, 2007, 10:58 PM   #2
neverfastenough1's Avatar
Sounds like fuel starvation. Clogged injectors, clogged fuel filter, pinched line, etc.
Old May 26th, 2007, 11:27 PM   #3
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
check the maf and the tps and the throttle body and all the stupid stuff like that
Old May 26th, 2007, 11:54 PM   #4
i'm thinking starvation aswell,, what is the MAF
Old May 27th, 2007, 12:01 AM   #5
You don't have it. You have the speed density. But it is a common upgrade from speed density to maf.
Old May 27th, 2007, 12:11 AM   #6
thaught so.... people trying to pull a fast one on me.
So i guess the main prob to create popping is a fuel shortage
Old May 27th, 2007, 12:35 AM   #7
SALIV8's Avatar
SALIV8 is on a distinguished road
whats ur timing at?
Old May 27th, 2007, 02:22 AM   #8
LoL, I don't think he was trying to pull a fast one, just didn't realize you said you had speed density or saw it was a 86. It could be fuel, timing, or even poor spark. Number of things, I just like to start with the easy stuff to check.
Old May 27th, 2007, 02:26 AM   #9
timing and spark is all good.. Like i said at idel it is top notch,, only under load does it act funny,,, now, could this be a possible Oxygen sensor prob??
Old May 27th, 2007, 03:24 AM   #10
Yes, but more than likely it would be a stored failure in your computer and you would get a light. Your o2 sensor does determines how rich or lean your car runs. Also check your air filter to make sure you are getting enough air, but I think popping is too much air and not enough fuel. Sorta like an acetelyne (sp?) torch. Too much oxygen and it will pop and shut off. Still check it out to see if it is clogged. I just told someone else that a clogged cat will cause hesitation, but I am not sure if it will cause popping. You can check that at night by looking to see if it is red after driving.
Old May 27th, 2007, 10:19 AM   #11
tording92lxnotch is on a distinguished road
Originally Posted by SALIV8
whats ur timing at?
I know you said your timing is good but what is it actually set at?
Sounds like it could be a timing issue.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old May 27th, 2007, 06:53 PM   #12
chadjones99's Avatar
chadjones99 is on a distinguished road
my 86 did the same
my 86 was doing that, but it is a mAF converted car. it turned out to be bad o2 sensors and i had a broke o2 wire, the car thought it was running rich so the computer was leaning it out way to much.
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion
Old May 28th, 2007, 09:23 AM   #13
timing is set to 13 degrees.. and o2 sensors are brand new.. I will however check the air intake for clogs. i'm getting really close to scrapping the whole EFI and switching over to carb and intake...lol
Old May 28th, 2007, 07:27 PM   #14
have you checked your cap and rotor ?
and plugs, i have had problems with the ford racing wires before.
Old May 29th, 2007, 09:56 AM   #15
B.A.M302 is on a distinguished road
Send a message via AIM to B.A.M302
Check and make sure a vacuum line is connected to your fuel pressure regulator. Mine did the same damn thing. Its definitely a fuel problem.
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55,
Old May 29th, 2007, 10:19 AM   #16
o.k I went through all the wiring, cap rotor,, and everything else...shit..... Then i ran a comp test and came out with codes 67,81,& 82.... code 82 delt with the MAP sensor so i tries to change it and took it for a run and same old crap,, and same readings keep coming up on the diagnostics check.
Old May 29th, 2007, 12:47 PM   #17
Did you address the fuel pump and ect trouble codes as well. If you have a voltmeter this link will show you how to check the ect. If it is not working properly it will affect the air fuel mixture. You would need to check it because other things can affect the ect to have it trip a code. ECT engine coolant temperature sensor.
http://fordfuelinjection.com/?p=28
Old May 29th, 2007, 01:16 PM   #18
oh shit... i have an aftermarket temp senser, with the origonal wiring harness unplugged... I mentioned this to other people before and they said that the coolent sensor has nothing to do with the computer and the way it acts upon the rich and lean functions..
quick question:: the sensor we are talking about, is it the one on top of the manifold right behind the coolent return hose?? If it is that is the one that has been replaced by the aftermarket sensor
Old May 29th, 2007, 01:20 PM   #19
by the way,, i am pretty sure the car is running way too rich.. I have nice stainless pipes that i wiped down before takeing the car out for a little rip (about 1-2 miles) when i returned the inside of the pipes were pretty built up with a skin of carbon.
Old May 29th, 2007, 03:17 PM   #20
o.k i am retarded, i mixed up the temp sending unit and the ECT.. but does the origonal temp sendingunit have to be plugged in or can an aftermarket one be used in its place
Threads Similar to: miss firing
miss firing the tick 5.0 Mustangs 5 August 22nd, 2007 11:03 PM
01' 3.8 firing order mattsthru V6 Mustangs 2 July 7th, 2007 04:29 AM
firing jonnotch 5.0 Mustangs 2 June 4th, 2007 06:04 PM
What is the firing order of... stang94 94-95 2 April 28th, 2007 07:13 AM
firing order 67-289-4v-coupe Classic Mustangs 2 December 14th, 2006 01:57 PM
