Back From Afghan, Lots to Update Y'all on Pics and Vids Inside
Old October 20th, 2011, 06:39 AM   #1
Timm10221's Avatar
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Timm10221 is on a distinguished road
Haven't been on here in a while thanks to the computers in Afghan blocking this site! Buncha fuckers right lol. I got home almost a month ago and been a very busy guy with the new "Racecar" My 88 Notch. I will post a few posts in this thread with Vids and Pics so yall can see the progress and What old Timmy's Been up to haha.
Right now the car is Running a best of 10.59 at 132 with a 60' of 1.64 NA. I haven't hit the fogger yet cause I know this car had been 10.3x before and thats with the Smaller headers and Vic JR intake. Now she has the Super Vic and 1 7/8 inch headers to 3.5 inch collectors. She is laying down twice in my run, once right at the 60' and then when I slam her into 2nd. The vids I will post below you can hear it. I wasn't able to tune it out last T&T cause I had to leave but I got home and Raised the Float levels a tad as they were a bit low, I am going to up the fuel pressure to 6.5-7 psi from the 6 it's at and see if that works. I also noticed when I was trying to start her to drive it home the Fuel pump wouldn't turn on and I looked at the wiring and noticed the connections were crummy so I am going to solder them for a no shit good connection.
I had the Car Painted and straightened out to Black. Interior is put back together somewhat, but not worried about that as it is a 100% Drag car so oh well lol. I have what I need in the car to Run 275rs and thats it Once the car Touches Low Low 10's I will hit the spray. 250-300 shot Then I will be running 1/8 mile because these tracks here are a paint to stop 132... so 150+ would be a bit much haha.
Build and pics Below!
Military Crew USMC
Originally Posted by JBIGBOOTSY
I usually kill the hookers(so I don't have to pay them) then I take their hands for my collection.
Originally Posted by homebrewed
Perversion mixed w/ mild tech... God I love ModdedMustangs!!
Originally Posted by flyin ryan View Post
Three Filipino hookers and enough for a co pay at the local clinic
Old October 20th, 2011, 06:41 AM   #2
Timm10221's Avatar
Military Crew USMC
Old October 20th, 2011, 06:43 AM   #3
Timm10221's Avatar
Military Crew USMC
Old October 20th, 2011, 06:45 AM   #4
Timm10221's Avatar
Military Crew USMC
Old October 20th, 2011, 06:48 AM   #5
Timm10221's Avatar
Military Crew USMC
Old October 20th, 2011, 06:49 AM   #6
EscortSportage's Avatar
1989 Mustang GT 5.0
See u at greatplains in nc?
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old October 20th, 2011, 06:51 AM   #7
Timm10221's Avatar
Military Crew USMC
Old October 20th, 2011, 06:54 AM   #8
Timm10221's Avatar
Military Crew USMC
Old October 20th, 2011, 06:55 AM   #9
Timm10221's Avatar
I T&T at Coastal Plain Raceway
Military Crew USMC
Old October 20th, 2011, 06:56 AM   #10
Timm10221's Avatar
Military Crew USMC
Old October 20th, 2011, 06:57 AM   #11
Timm10221's Avatar
Military Crew USMC
Old October 20th, 2011, 06:58 AM   #12
Timm10221's Avatar
THE BUILD:
The Motor:
-410 CU IN. SMALLBLOCK, 10.0:1 Compression, Runs on pump gas
-FRPP Sportsman Block
-J&E Custom Made Nitrous Pistons, Dish, installed Zero Decked w/ Hell Fire Rings. The ring lands have been moved down to try and help with the nitrous, keep from burning up the rings. Cranking Compression is 210.
-Eagle Forged Crank & H-beam Rods
-AFR 205 Heads "1450"
-Comp Cams Solid Roller, 260 Intake Duration 264 Exhaust Duration .672 Lift on Both Sides, 106 LSA
-Solid Roller Lifters
-Probe Shaft Rockers, Lash is .016 intake & .018 on Exhaust
-Edelbrock Super Victor Intake
-750 Race Demon Carb
-NOS Pro Race Fogger
-TCI Rattler Balancer, SFI Approved
-SFI Flywheel
-Power Master Starter
-Moroso Electric Water Pump
-Moroso Vacuum Pump & Lines
-MSD Dizzy & Wires.
-Kooks HTS Coated Headers, 1 7/8" Primary w/3.5in Collectors
-Edelbrock 71900 Progressive Nitrous Controller
-MSD Ignition Boxes
Tranny:
-Super Comp C4 Built by Performance Automatic
-Manual Reverse Valve Body w/Trans Brake
-10in TCI Custom Converter Made To "fit" my Motor. Stall Speed is 2400 on Motor & about 4000 on Nitrous
-B&M Double Stacked Cooler w/Steel Braided Lines
-Reverse Pattern Shifter by B&M.
Body / Chassis:
1988 Mustang Coupe
-UPR Tubular Suspension
-Coil Over Shocks up Front
-Aerospace Brakes
-10 Point Cage
-Black Interior
-5in Bolt on Cowl Hood
-Fiberglass Back Deck
-Sub Frame Connectors
-4.30 Rear End
-Moser Axles
-Spool
-UPR Upper & Lower Control Arms
-UPR Anti Sway Bar
-Welded Axle Tubes
-Nitrous Tank & Line
-UPR Coil Over Shocks in Back
-Weld Drag Stars
-Aeromotive 2000 Fuel Pump
-Fuel Cell
-2 Regulators
-All Braided Fuel Line
Military Crew USMC
Old October 20th, 2011, 10:10 AM   #13
1967 Mustang 302
67Sleeper is on a distinguished road
very nice
Old October 20th, 2011, 08:11 PM   #14
1995 Mustang GT
Bubba95SN is on a distinguished road
The passes made at Coastal Plains? Who did you finally get for the paint? Welcome home Marine.
Old October 20th, 2011, 08:59 PM   #15
ryanw's Avatar
1991 Ford Mustang GT
Welcome back
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 20th, 2011, 10:08 PM   #16
ghostrider05's Avatar
1989 GT 'vert
ghostrider05 is on a distinguished road
Great looking car, welcome back brother.
Old October 21st, 2011, 07:32 AM   #17
Timm10221's Avatar
Yup, Passes are made at Coastal. I got Shannon Young To paint the car aka Dentfix over on Horsepowerjunkies.com. He did a wonderful job on the coupe too I am still tuning and shaking down the car. This car with the Vic Jr intake mani and 1 5/8 inch headers ran a 10.3x, now she has the Super Vic and 1 7/8 inch kooks to 3.5 collectors.. So she should be good for 10.3x's on motor to 10.2x's I would think. The stumble in the 60' and the 1-2 shift is hurting my et for sure. I am fixing to head home to FL for leave but once back I will be out T&T'in the car to get down to low 10's before I hit spray Should be fun after that!!
Military Crew USMC
Old October 21st, 2011, 02:27 PM   #18
curtisboyte's Avatar
1993 GT vert
curtisboyte is on a distinguished road
sweet ride you got.
Old October 21st, 2011, 02:30 PM   #19
93 Mustang LX 5.0 5spd
N/A
easy-stangkin is on a distinguished road
Very nice Car/Build...great work!!
Old October 24th, 2011, 04:02 PM   #20
e3sean's Avatar
1988 lx
9.68@142
welcome home from a far lol. ill let you make a pass next to the orange beast before i let it go. cubes vs compression. equil spray amount.
<font size=4><b>MILITARY CREW
Threads Similar to: Back From Afghan, Lots to Update Y'all on Pics and Vids Inside
back on the road and better than ever...pics inside!! turbot4 99-04 72 September 17th, 2010 10:15 PM
Saw another guys afghan pic thread. Got some pics to, alaska/afghan Freedom Pictures 6 December 6th, 2009 11:29 PM
GOT MY CAR BACK (pics inside) xXJayManZXx17 Pictures 24 May 14th, 2009 10:56 AM
Motor Update Pics Inside Doc8224 4V / SVT 26 July 26th, 2008 05:05 PM
Y'all Might Enjoy These Vids 320hpPony? 5.0 Mustangs 7 November 1st, 2006 02:52 AM
