CEL under heavier accelereation
Old October 21st, 2011, 09:46 AM   #1
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
it just started this morning. but when i accelerate my check engine light comes on. then when i get back to cruising it goes off and wont come back on unless i down shift and speed up.
my car is a 91 lx with the 5.0 and a t-5 that i swaped in. cold air intake and the engine is mostly stock with around 85,000 miles on it
i was just wonder if maybe a sensor came unplugged or something simple like that because it doesnt feel like theres anything wrong with it
i also ran some fuel injestor cleaner through it a few days ago
thanks in advance
Old October 21st, 2011, 10:46 AM   #2
ryanw's Avatar
1991 Ford Mustang GT
It could be. A million things. This happened to me' but can't remember what the issue was. I think it turned out to be bad plugs and plug wires. Or maybe my fuel pump was on it's way out. Run your codes first. Check your fuel pressure and do a basic tune up if it hasn't been done in a while
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 21st, 2011, 11:27 AM   #3
brandon444's Avatar
91 Mustang LX 5.0
i know i have a small fuel leak ina fuel line. you think maybe that injector cleaner cleaned out that crack enough for more fuel to leak out causeing a lowrer fuel pressure
i should be able to run the code later today
Old October 21st, 2011, 12:59 PM   #4
brandon444's Avatar
91 Mustang LX 5.0
and now no light. wtf?
Old October 21st, 2011, 01:19 PM   #5
fogged306's Avatar
89 GT
Code should still be stored though, so check it anyway and see what it says.
Threads Similar to: CEL under heavier accelereation
Any benifit to heavier wheels? therat1989 99-04 3 November 28th, 2010 07:38 PM
Are convertibles heavier? ReikokuKo 99-04 53 March 5th, 2010 05:51 PM
?Heavier Injectors? 03GetThere 99-04 22 January 20th, 2009 03:36 PM
Heavier Injectors? highwayman24 2005 - 2010 3 November 21st, 2008 06:49 PM
Whats Heavier 96GtGoodz 96-98 43 December 23rd, 2007 09:43 PM
