car cutting out..please help
i have a 347 stroker motor and i think it might be a fuel problem but when i am just driving normal and even when i get on it it cuts out and kind of hesitates..please give me suggestions i have a 110 LPh fuel pump in it right now is a walbro 255 calling my name?
Lets start with some easy stuff. I am all about the easy stuff. Do you have cats still or off road mid pipe? If you have cats do you have a smog pump? Again, if you do, check at night to make sure they are not getting red hot after driving around. Did you change your fuel filter when you put the motor and pump in? Did you change your air filter? All of these things are common problems that cause hesitation. Did it just start doing it or has it been doing it since you put the 110 in it?
#3 | |
Re: car cutting out..please help
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller 13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock |
#4 | |
89 GT
Did you check your spark plug wires?
Stock is like 80 lph. I believe it is 18 gph which is like 76 lph or close to it. Yes there is a 110lph. Anyways, since you blew all the easy stuff out of the water, we'll have to go to the water issue. You got me how the water would affect it that way. If it is only happening after you wash it, that it has anything to do with the size of you pump. Unless it is just a coincidence. Is that the only time it is doing it? We are back to square one. Your tps will cause hesitation. I don't know if it would cause a problem if it got wet or no. I'll back out and see if someone else can help you out. It is time (past time) for me to call it a day. Try to see if there are any codes that aren't tripping a engine light. Good luck.
ya i just put new MSD spark plug wires and made sure they were firmly on the cap and the spark plugs....no when i wash it it does it more than regular ..and agian this just started happening ..i just put new blaster coil wires and cap and rotor on it ..thanks for your help i will try to fing out
#8 | |
all motor
92 coupe
9.94@136.40
#9 | ||
89 GT
alright hey guys its not the ignition...well it might be but there is no arcing at all...and i noticed that the cutting out goes away completly after i drive it a little bit...not after it warms up because i always wait tilll it warms up but after i drive it..any suggestions?
all motor
92 coupe
9.94@136.40
is the ecu throwing any codes? what's the fuel presure at? what injectors are you running
my car did the same thing, driving around normal it was fine but as soon as i got on it...lots of vibration...it cut out then back on, then finally it turned off all
together...turns out it was the wires that went to the starter, they were rubbing on the header and grounded out. so u can check that. i also thought it could be my fuel filter and pump...
I just read an article about the dangers of drinking ... And it scared the crap out of me. So that's it............... After today, NO MORE READING. |
alright so i havnt checked the codes yet BUT i have 30 # injectors and its around 40-42...it is inconsistent though...i will start it sometimes and it will be at 37 psi and then sometimes at 42psi
Threads Similar to: car cutting out..please help
| Cutting Out | Illuminator | 5.0 Mustangs | 2 | November 13th, 2007 10:45 AM |
| car cutting off | raceruler03 | 99-04 | 4 | April 14th, 2007 11:40 AM |
| cutting my antenna? | TheTechnical99 | Audio/Video | 10 | January 2nd, 2007 11:04 PM |
| Car is cutting out top end!! | boosted89 | 5.0 Mustangs | 7 | November 19th, 2006 07:15 PM |
| Car Is Cutting Out! Help! | streetstang06 | 96-98 | 10 | September 14th, 2006 08:17 PM |
