1994 Mustang GT
Coolant Leak!!!
having more and more issues seems like every effin day. Just last night got home and i heard a weird hissing noise coming from under the hood, checked and i smelt coolant. I looked under and it was leaking very bad. its hard to tell where its coming from, not the hoses or the radiator or the reservoir tank...it looks to be coming from the front of the engine and the trail of the leak looks to be going behind the air pump up to the front part of the engine and the i cant see nothing from there. any guess or hear of any similar problems?
1990 ford mustang GT
could be a a lot of things. if u can get your hands on a pressure tester that will pinpoint the leak. if you can't, try filling the coolant again and let it idle. grab a inspection mirror and start backtracking the trail if leak, it should be very easy to find the leak since u stated it's leaking pretty badly.
1992 mustang Lx
13.4@ 106
my guesses would be the lower intake manifold in the valley/corner of the valley and head, or underneath of the water inlet for the lower intake manifold. I have had a lot of trouble with those two spots in the past.
![]() 1992 5.0 lx_soon to be powered by a m122 GT500 supercharger
1990 Mustang GT
Id check the thermostat housing too.
![]() 1990 Mustang GT |
1994 Mustang GT
Its weird because it seems to be intermittent. its not for the thermostat housing. i just replace the gasket to it and no leaks. it was leaking from there originally. now its a new spot.
1994 Mustang Cobra
if you have the extra funds run the parts store and get a uv light and the die for coolant that stuff works so nice for finding any coolant leak.
1994 Mustang GT
Yeah that might be my best bet. what im gonna do is when i have the time is check the timing cover....
1994 Mustang Cobra
that could be one spot another spot where mine leaked was the heat hose pipe that screws into the intake on the passenger side up front I had that leak once also.
1989 Mustang GT 5.0
Its funny u say that, my thermo just went, she saw 230 degrees real quick
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
1994 Mustang GT
#11 | |
1994 Mustang GT
1994 Mustang Cobra
^ I didn't have my thermo go but my upper split wide open about 6 inches on my way home one night I thougt it was a freak rain storm lol but no my winshild was coated
#13 | |
1994 Mustang GT
Threads Similar to: Coolant Leak!!!
| Coolant Leak....STILL | maxsideburn | 99-04 | 54 | October 4th, 2010 11:40 AM |
| Coolant Leak on '06 | sephstrom | 2005 - 2010 V6 | 2 | March 27th, 2010 05:24 PM |
| Coolant Leak | screamins197demon | 2005 - 2010 V6 | 5 | February 28th, 2010 06:06 AM |
| coolant leak? | shadow98gt | 96-98 | 3 | May 14th, 2007 02:59 PM |
| Coolant leak? | shan | 96-98 | 12 | April 26th, 2007 08:52 AM |
