95ish5.0
Put in another motor.
So this weekend and the prior weekend, my dad and I embarked on a mission to take a motor out of a 96 e-150 and put it in my car. We got both of the motors out in a weekend, and had started taking parts of the old motor to put on the e-150 motor. we actually completed the swap this weekend, and man, it was worth it.
The car has a slight exaust leak, though, and we pinpointed it down to the flange. Not only this, but we had also known that the bell housing was cracked when we had first taken the motor out of the car a month ago to replace a crank we thought had been causing a knock. After a lot of hard work this past weekend, we ended up having the motor put in the car. after some timing change, the car fired up and ran 100x better than before. I also noticed that when looking for the bell housing on AM, the transmission i have looks very similar to that of the tremec-500; whatever sub-category it's specified under. Hopefully this thing hasnt been abused as much as the motor, but I'll end up putting the tender loving care into the tranny as needed anyway. I am pretty happy that the car is in working order, for now. We do have a couple more issues to fix, other than the bell housing, and should have this thing in nice working order by january of next year when I get the rest of my funds. |
1989 Black LX---Turbo
Glad everything worked out for you. That's a whole lota work!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
95ish5.0
Haha yeah it was a very large and substantial amount of work we did this weekend. we went from about 10am to 1 am. Worth it in so many ways, though.
1991 Ford Mustang GT
Wow. Ya that's a lot of work. It took me' a month and half to do my engine swap. Lol. But I did do it all by my self. But some of that time was waiting for parts to come in. But on the other hand I only had to pull one motor and one tranny. The new engine was just sitting on a stand. I think even if I had help I still wouldn't have had it done in two weekends. It was my first engine swap though. Any ways good job
#5 | |
95ish5.0
1999 mustang gt
did u have any trouble with the new motor coming from an E150? like it having a different fireing order and ca?m
1990 mustang gt, gt40heads f303 cam , and bolt ons |
#7 | |
95ish5.0
1999 mustang gt
ok. but dont does blocks have flat top pistons? wat cam and heads did u use?
did u have any issuses with the valve clearnce
Threads Similar to: Put in another motor.
| exploded views of stock 5.0 motor front of motor | White 89 | 5.0 Mustangs | 9 | October 15th, 2010 05:58 PM |
| 2000 v6 motor change to explorer 4.0 motor | v6must742 | V6 Mustangs | 29 | May 25th, 2009 05:03 PM |
| How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? | Jonathan | General Tech | 3 | January 2nd, 2008 09:34 PM |
| need some help american motor to import motor | wadepetersen | V6 Mustangs | 29 | May 30th, 2007 09:26 AM |
| How do you find the motor code on a 88 5.0L motor? | semihemi428 | 5.0 Mustangs | 1 | March 16th, 2007 04:56 PM |
