My5.0 is Sluggish and popping in low rpms ?
Old October 24th, 2011, 01:29 PM   #1
cornellm5 is on a distinguished road
I have a 306 heads and cam full bolt-ons and when I drive my car it's real sluggish and pops from the exhaust then when I get past 4 grand it's perfect so what can I do to fix this problem would a tune do it ?
Old October 24th, 2011, 05:40 PM   #2
428CJ's Avatar
428CJ is on a distinguished road
My car does the same thing, Check your fuel pressure.
1988 Mustang: 5 speed, hurst shifter, plenty slow.
Old October 24th, 2011, 06:12 PM   #3
I raised my fpr to 45psi
Old October 24th, 2011, 07:54 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
check your codes and fuel pressure. your fuel pressure should be around 39 psi with the vacuum line disconected from the fuel pressure reg.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 25th, 2011, 08:25 AM   #5
I did that and it's at 39 psi would me not having a better fuel pump cause this cause I still have the stock one n
Old October 25th, 2011, 08:53 AM   #6
Better than Drugs!
mayosailor27's Avatar
97 Cobra makin' women wet
Decent @ A fast one
mayosailor27 will become famous soon enoughmayosailor27 will become famous soon enough
run codes, check timing, test coil, check o2 sensors. I had the same problem. turned out to be timing being off. sometimes a bad coil can do that. once it heat's up, the circuit opens.... low rpms arent needing as much spark. high rpms, youll see-- try it out
96 GT-sold
98 GT-05 katrina victim-parted
90 GT-traded
98 GT-traded
98 GT-parted
94 GT/Cobra-sold
95 Cobra Saleened-sold
97 Cobra-knock -sold
99 GT-knock-sold
97 Cobra-sold
96 Cobra-nothing wrong but stock!
MM Cobra member 969
Old October 25th, 2011, 01:49 PM   #7
And my timing is set to stock would that change anything if a heads and cam car timing is stock
Old October 25th, 2011, 05:24 PM   #8
ryanw's Avatar
It's possible that your balancer has spun And your timing is not reading correct. What codes showed up. Did you check yet?
255 fuel pump,
3:27 gears
Old October 25th, 2011, 05:41 PM   #9
No code is showing I have a 87 and no engine light is on or anything
Old October 25th, 2011, 07:28 PM   #10
1994 Mustang Cobra
steveofire is on a distinguished road
just a thought but have you cleaned the maf lately I fixed a lot of cars that had a dirty maf on it one was a van that wouldn't rev past 3k it would just pop and no power I cleaned it and ran like a brand new van and it didn't throw a code
Old October 25th, 2011, 08:27 PM   #11
ryanw's Avatar
^ good point, id try that, but i would have thought a code would have shown up for that
255 fuel pump,
3:27 gears
Old October 25th, 2011, 10:24 PM   #12
1994 Mustang Cobra
I here ya my 94 did kind of the same thing with a turbo setup but it started to run on the rich side and was doing some of the same things never got a code and I finally tracked it down to one side was nice and clean and the other was coated with dirt lol
Old October 26th, 2011, 11:26 AM   #13
My maf is new
Old October 26th, 2011, 11:30 AM   #14
I'm gonna change out my 02 sensor as well cause when I first put the motor in with the cam I have it was dumping alot of fuel and kept fouling out the spark plugs I went thru two sets so I didn't the maf conversion so I'm guessing all that fuel that was coming out of my pipe could have messed up my 02 sensors
Old October 26th, 2011, 11:47 AM   #15
C Mor Semen
SNmustang95's Avatar
1995 Mustang GT
Not fast enough
SNmustang95 is just really niceSNmustang95 is just really niceSNmustang95 is just really niceSNmustang95 is just really nice
This happened when my maf was going bad. Unplug it, and go for a quick drive and see what it does. It really might be your maf, even if it's new, the wire could have been touched and messed it up.
Originally Posted by 4.6DreameR View Post
I would hit it like the fist of an angry God!
Originally Posted by cotton View Post
just wasted my whole night on this thread
Originally Posted by HurrycaneStang View Post
Wait till you waste your entire life on this forum...
MAC CAI, SLP LM1's, Steeda short throw shifter, UPR O/R X Pipe, 3:73 gears, and more to come.
Old October 26th, 2011, 01:42 PM   #16
1995 Mustang GT
primetizzle is on a distinguished road
Okay wow I have the same exact problem...same engine also, 306 with just about every bolt on. When my car is cold it runs like shit- pops, stutters, back fires...but once my check engine light kicks on it runs like a champ...more then one person suggested cleaning the MAF, I decided to just replace it with the BBK 76mm CAI calibrated MAF...still same issues tho :/ what do you guys think?
Old October 26th, 2011, 02:01 PM   #17
1994 Mustang Cobra
What codes are you getting when the cel comes on ?
Old October 26th, 2011, 07:58 PM   #18
ryanw's Avatar
If the o2 sensors were making your car run lean or rich, a code should be showing. Make sure that your check engine light is not burnt out, cuz you should have some codes, even if code 11 pops up wich means all system pass
255 fuel pump,
3:27 gears
Old October 28th, 2011, 12:18 PM   #19
1994 Mustang Cobra
a couple other things you could check is check the tps make sure it has a nice sweep on a volt meter and u can check the voltage on the maf to make sure it has a clean sweep also and if you have a fuel pressure gauge hook it up and try to put it so you can see it or just take the hood off and mount it and go out and get on it under a load and make sure your fuel pressure isn't dropping off under the high loads
Old January 1st, 2012, 01:18 PM   #20
1995 Mustang GT
yup ended up being the coil. I replaced the intire intake set-up and installed a hole new ignition system. But still have a very slight miss...can't figure it out to save my life.
Threads Similar to: My5.0 is Sluggish and popping in low rpms ?
why does my car run sluggish during first start up JACK MEHOFF 99-04 3 May 31st, 2011 01:20 PM
sluggish ? :/ kenpachifknpwns 2005 - 2010 V6 42 June 10th, 2010 11:29 PM
Car is sluggish. MustangMo V6 Mustangs 12 July 21st, 2008 06:50 PM
Sluggish? MustanG_guy17 V6 Mustangs 9 June 14th, 2007 02:36 PM
97 GT feels very sluggish jbm5781 96-98 11 April 22nd, 2007 01:35 PM
