Trickflow Top End Kit.....
Can you just throw everything on the block....I'm trying to budget this project so that I have everything ready to install all at once...thanks guys
I couldn't find anything using the search feature...but I'll look again
2000 A4 Z-28 Free Mods No Appearance or Performance mods Yea, it's slow.....
#2 | |
I Post Entirely Gay Too Much
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
you can I supose. assuming you check everything before fiering it up. Every engine is different
how is every engine diff. when they all hav the same specs.. unless its a aftermarket block or whtevr. anything other than stock...
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip |
well some engines have been abused and/or neglected...you might find something else needing to be replaced once you get it appart...thats all i can think of how engines are different.
95' GT is being reconstructed! |
well of course tht but he made it seem like it wouldnt jus work or somethin, and its alwayz best to do a compression check b4 upgrading heads.
#6 | |
you can take 2 hand guns made by the same company with the same specs and each one will strike the bulliet in a diff spot. granted it will prob not affect what he is doing. but sometimes that thousands of an inch matters.
#7 | |
89 GT
And otherwise this is a completly usless post that has nothing to do with the original question........ and we are all now dumber because of it. I award you no points, and may god have mercy on your soul. |
#8 | |
your right I did just hear a lot of
if someone who owned the car before him rebuilt the engine and milled the block shit could hit the fan quick. your right that post was pointless slap it on there and fire it up.
89 GT
Maybe I was a little fuzzy on my post dr.gonzo, I was saying that I agree with you. And I was talking about my post as being the usless post that has nothing to do with the original question.....as does this one.
Basically what I was getting at is that the tolerance difference that the factory leaves can actually make one mustang outperform or outlast another exact same mustang. Thats why the "tune" from the factory can be improved upon because they set it on the safe side to make sure the ones made on the low side of the tolerance will live longer. |
#10 | |
Re: Trickflow Top End Kit.....
I would say anytime you are going to go this far into the engine, you might as well pull it. It isn't that much work and it is a lot easier to work on the engine while it is on a stand that in the car. you can install the kit with the engine out and put the whole assembly back in. Things to think about, you are already going to have the accessories off, radiator drained, water pump gone (for the cam), exhaust and intake off. If you are doing the clutch (which you should) you'll have the tranny off. At that point it is almost easy to pluck the block and at lease give it a once over with some new bearings, rings, seals and gaskets. you'll be glad you did. |
Ok thanks, that sounds like a good route to go...maybe even stroke it while I'm at it?
#12 | |
some pepople are not happy with 347 and by the time you do all the machine work you could have a 351 but the 347 is lighter
Threads Similar to: Trickflow Top End Kit.....
| Trickflow problems.... | Casper98GT | 5.0 Mustangs | 41 | September 24th, 2007 10:48 PM |
| Trickflow for 4.6 | mustang03GT | 99-04 | 21 | August 5th, 2007 09:14 PM |
| trickflow intake? | Wildsteeda | 99-04 | 7 | May 28th, 2007 09:17 PM |
| new trickflow plenum | raceruler03 | 99-04 | 1 | May 4th, 2007 10:24 AM |
| Trickflow | 1993 5.0 | 5.0 Mustangs | 1 | November 30th, 2006 12:31 AM |
