Gt40 non p head swap
Ok guys ii have a 70 coupe with a 90 gt motor in it converted to cardurator. I just pickef up a set of gt 40 non p heads off a 97 explorer. Are these a direct bolt on or what will I need? New rockers? Pushrods? Ect. im new at this head swap part of the building proocess.
I just installed P's, everything should just bolt on for you. I'm not sure but I think you need new valves springs. You should be able to get away with using your mustang's springs on the gt40 heads if the heights are the same.
So push rods will line up and can I use my stock rocker arms or do I need 1.6 or 1.7 rr since im gonna get some prolly later on if I dnt have to right now
1991 Ford Mustang GT
You should still check push rod length and piston to valve clearance. If you buy the right size after market cam later on down the line then you shouldn't need 1.7rr. Going with 1.7rr is really only needed if your trying to get more lift out of your existing cam. That's how I understand it any ways. If I'm wrong then some one correct me
how do i check piston to valve clearance? im running stock cam and dont plan on upgrading it anytime soon as i plan on doing a bbf swap in the near future!
i dont want to change springs if i dont have to. i ust plan on gasket matching and having a valve job done and would like to bolt them on a stock bottom end. can i use my e7 rocker arms or do i need 1.6rr? |
Bump someone help plz
you can use the same rockers. The thing with the springs is I think the HO cam is more aggressive than the stock springs on the gt40 heads were made for, but if you use your stock HO springs then you know they will be fine. That's if they have the same installed height etc, which I'm pretty sure they do. You definitely shouldn't have any piston to valve problems with the stock cam and rockers or even 1.7 rockers.
So now my question would be will my stock pushrods match up?
yea they will always line up, do you mean too long or short? They should be perfect unless the heads were milled or you have a cam with a different sized base circle or anything that would move them up or down in relation to the valve stem.
Yes d I mean length sry didnt specify. And stock cam. Not gonna mill the heads as they are not warped or anything jyst some gasket match porting. What springs do u suggest if I wanna go aftermarket instead of using my e7 springs
if your gt40 head's springs installed heights etc are the same as the gt40p's which I think they are, then I'd go with the 44308-1 crane cams kit. I did a lot of researching for the springs to use on my heads, and those seemed to be the best from what I've read. You can use the trickflow TFS-2500100 kit too, but some people have complained about them having cheap retainers and soft locks so I went with the crane cams kit.
Pushrods should be identical, when I did my gt40p swap we measured the spring rate from the stock heads to the P's, springs were basically the same, I ran the gt40p springs shimmed with the GTP rockers (same as the stock mustang rockers anyhow)... and actually from what I've read the stock explorer/mountaineer cam is a bit more stout than the stock mustang cam, i'm not 100% on that though
Threads Similar to: Gt40 non p head swap
| Gt40 head help | Stevo077 | 5.0 Mustangs | 2 | June 2nd, 2011 08:51 PM |
| bronco gt40 head? | NASTYWHITE93gt | 5.0 Mustangs | 8 | August 9th, 2010 09:18 AM |
| GT40-P Head Specs? | RDY4WAR | 5.0 Mustangs | 2 | March 29th, 2010 09:34 PM |
| Gt40 p head price | Thlad | 94-95 | 18 | July 11th, 2009 11:35 AM |
| Gt40 Head Swap | sx455 | 5.0 Mustangs | 7 | April 24th, 2008 02:20 PM |
