95 5.0 vert, problem
Old October 25th, 2011, 10:57 PM   #1
mdhbeast is on a distinguished road
so my friend has this car, he says that the fan does not run when it on but it does when the engine off. has anyone had this problem before or have heard of it. i will probably check out his car later this week to see. he was thinking if he cant find the problem, just hard wire it to a switch. i was thinking maybe its a sensor, any thoughts would be helpful. i read about 15 other forums with people having fan problems and there was nothing similar to this.
Old October 26th, 2011, 12:10 AM   #2
1994 Mustang Cobra
steveofire is on a distinguished road
mabey check the temp sensor in the heater pipe on the intake also there is a wire on the relay box by the over flow tank that you can run a ground to one of the green wires i believe and that will put the fan on high all the time that's what I ended up doing with mine
Old October 26th, 2011, 01:21 AM   #3
ill check that and get back to you
Threads Similar to: 95 5.0 vert, problem
Will these fit my vert? 510jatt 99-04 15 June 12th, 2009 03:47 PM
New Best for the Vert Stkjock Drag 6 April 5th, 2009 07:03 PM
help with 95 gt vert! pnyboi 94-95 14 September 26th, 2008 11:32 AM
