Bad idle from my B303 - Page 2
Old October 28th, 2011, 03:39 PM   #21
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Detonation is when the mixture pre ignites in the combustion chamber. There are a few things that will cause it, but in the sense that we are talking about, we will just say it's due to excessive timing. if your timingnis advanced too much, the plug will fire too early, and cause detonation (pinging, clatter, ect). It is very harmful to rings, bearing, pistons, pretty much everything.
Raising the timing will increase the idle. In a very basic sense, you want to run as much timing as possible, without detonation. More timing makes the engine much happier, aside from detonation. Plugs will live longer, idle is better, and cleaner, ect..... And it will make more power. With said, setting it on then safe side is always best. It's not a racecar.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old October 28th, 2011, 03:44 PM   #22
93Lx.Conv5.0's Avatar
1993 Lx Mustang Conv.
93Lx.Conv5.0 is on a distinguished road
ok cool i understand... because i was having a problem with people keep telling me my car suppose to idle around 750... when my timing is up alittle and i can't find no possible way to get it that low
Old October 28th, 2011, 04:44 PM   #23
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Your car should where it like to idle. In the last two videos, mine is idling a touch over 1000 RPMs.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 28th, 2011, 05:23 PM   #24
ok i see what you saying... can't make it do nothing it don't want to
Old October 29th, 2011, 08:32 PM   #25
e3sean's Avatar
1988 lx
9.68@142
do a base idle reset on it to be sure. use the green wire coming from the TPS check the voltage KOEO position should be sitting .95-1.0 .98 is ideal and should go up as throttle is opened up. at WOT should sit around 4v.
reset your timing completely check TDC, the position of the magnetic prongs for the fuel injectors, and of course check your timing and make sure the jumper is out when checking it and then back in when done.
pull yout IAC out and clean it very good.
run some seafoam through the intake while the car is running.
last of all adjust your idle to around 800
<font size=4><b>MILITARY CREW
Old October 30th, 2011, 02:02 PM   #26
yeah so i'll just adjust my idle to 800 lol, out of the 5 things you said i did yesterday the timing and the idle... just so happenes that it will take 800 smoothly with out shaking.
Old November 11th, 2011, 05:49 PM   #27
1FAST6's Avatar
1989 LX hatch
15 and change
1FAST6 is on a distinguished road
is the cam installed at *4 advanced? Check into a stall converter and swap the ecm with one from a manual car.
1987 Buick Grand National
1989 Mustang LX 5.0
Both BLACK
Threads Similar to: Bad idle from my B303
Installing B303 & 1.7's 8994 5.0 Mustangs 13 February 17th, 2009 09:34 AM
B303 Cam acmillr 5.0 Mustangs 32 November 9th, 2007 09:10 PM
B303 cam homebrewed 5.0 Mustangs 21 March 9th, 2007 12:07 AM
b303 cam with 1.72rr's bigbadtalontsi 5.0 Mustangs 5 January 16th, 2007 06:36 PM
