1992 mustang Lx
13.4@ 106
Cleaning Things Up
So I just rerouted wires in the engine bay and finished that up about a week ago and got the engine bay looking nice and clean. Now its time to start on the underside. I cleaned the trans tunnel a few months ago when I had the tranny out so thats already done. Got the passenger side nice and clean today. I'm just going to keep adding pics of the cleaning up process to this same thread whenever I get stuff done.
Dirty Side ![]() Middle ![]() Cleaned side
![]() 1992 5.0 lx_soon to be powered by a m122 GT500 supercharger
1991 Ford Mustang GT
big difference, over the passenger side. looks good. lets see some pics of the engine bay, i wanna see the wire re routing
1992 mustang Lx
13.4@ 106
Some pics of the engine bay wiring for ya ryan, I have another post with them but I'll put them here since I'm going to start putting everything here anyways. I feel like I already want to do it over and get the main harness behind the dash now... I also wanna pull the motor and weld up the holes.. there is so much more I want to do every day. I guess that why call it a project!
1991 mustang 5.0
That engine bay looks so clean!
1990 Mustang GT
I like how you routed all the wires in the bay. Looks clean.
did you have to splice any wires and add on to it to reach all the locations ? it really does look clean, good job....
The only thing id be afraid of is not having access to the starter solenoid. the starter solenoid makes a great junkction point and i would like it vary accessable. but they are ugly as hell.lol Im tempted to do the same.
Man that is a nice clean engine bay for sure. Great job man.
![]() Sig by Tricep |
1992 mustang Lx
13.4@ 106
Thanks guys I really appreciate it!
Ryan I did have to splice and add wire to the master cylinder fill tank? lol not sure what it is exactly but that and I did buy new wire for my starter to reach the solenoid. 4 gauge for the positive and one 12 gauge to go to the negative side. My dad said the same thing about the solenoid! It is accessible with the inner fender well removed... but it would still be a pain to deal with! The inner fender is a PITA all in itself. Ahh lets just hope there are no issues! Nothing beats the clean look though, but I see others that are way better that make me want to do better lol oh well. If u end up doing it be sure to take pics and let us know!
i couldnt tell from the picture, but did you hide the main part of the wiring harness ? the big fat one the runs a long the fire wall, the salt and pepper shaker and engine sensors and injectors all conect to it ?
1992 mustang Lx
13.4@ 106
I just tucked it under the the clip that goes across the rear and pushed the salt and peppers a little lower. If you end up doing you should hide it behind the dash or you might end up like me and want to do it over to hide the main harness completely!
1994 Mustang Cobra
very nice and clean I plan on doing this to mine over the winter also
1992 mustang Lx
13.4@ 106
Cleaned the passenger undercarriage and painted the drivers side. I'm going to take the trans out so I can get to the tunnel and do the rest tomorrow hopefully.
89 GT
Easy way around that is to use a mini starter from a late fox/SN-95 car with the solenoid built into the starter, and replace the solenoid on the fender with a fuse block or some other type of terminal.
1989 Mustang GT 5.0
Damn u ur making me want to do this now, my friend has been doing wire tucks for the longest, he tucks wires inside the radiator support, inside the fenders like u and in the dash. It looks so clean after. So simple almost like a carbd setup
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
1992 mustang Lx
13.4@ 106
Just some of the progress I've been making. Took everything out and sanded the one side I had previously painted and primed the entire underside then painted after all was completely clean. All break lines have been sanded and painted hammered metal.... but as you can see in the pic I missed a spot but I'll get it! Also painted the rear differential, axle housings all the way to the ends. It's really starting to come a long. looks better in person. In the garage now while its torn apart, but once its done I'll get pictures in the daylight.
2008 Jeep Rubicon
a brick can go faster
That looks SEXY! Projects like this make me want to pic up a cheap fox and go at it.
1984 Cougar GT
thats hella KLEAN
1992 mustang Lx
13.4@ 106
All it takes is a little money and a Lot of time! I kind of wish I had started with a cleaner mustang but now I've got the itch and I want everything crisp and clean.
1995 Mustang Gt
wow...awesome job man!! im def doing that and have always done that to all my cars...i am ocd with cleaning
95' GT, Trickflow setup, Aluminum heads with 1:6 roller rockers, e303 cam, BBK shorties into Magnaflow exhaust, BBK cold air intake with 75maf, Highperformance waterpump w/ electric fans |
Threads Similar to: Cleaning Things Up
| Cleaning up around here... | Zatrekaz | General Car Care & Detailing | 5 | October 17th, 2011 03:59 PM |
| CF cleaning | Tom-e09 | General Car Care & Detailing | 5 | April 18th, 2011 10:40 PM |
| CAI cleaning | spike spiegel | 99-04 | 8 | September 27th, 2008 09:38 AM |
| engine cleaning.. and other things | Ninjawafers! | V6 Mustangs | 13 | June 25th, 2007 08:25 PM |
| Cleaning the EGR? | fastford3388 | 5.0 Mustangs | 1 | May 24th, 2007 04:36 AM |
