Tips on releasing horsepower.? - Page 2
Old October 27th, 2011, 10:44 AM   #21
93Lx.Conv5.0's Avatar
1993 Lx Mustang Conv.
93Lx.Conv5.0 is on a distinguished road
yeah and electric fan is something i surely can do. and the msd stuff i already have racing wires and aftermarket plugs and the msd distributor cap. idk if the cap really makes a difference over stock if you don't have the whole msd set up ignition,coil,and distributor
Old October 27th, 2011, 10:45 AM   #22
idk what kind of rockers they are. there the stock ones that come on the E7 heads what ever they are.
Old October 27th, 2011, 03:40 PM   #23
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
I don't see why people need to delete the EGR its fully closed at WOT
Old October 27th, 2011, 03:58 PM   #24
whats the EGR.?
Old October 27th, 2011, 05:31 PM   #25
1994 Mustang Cobra
steveofire is on a distinguished road
The EGR valve controls a small passageway between the intake and exhaust manifolds. When the valve opens, intake vacuum draws exhaust through the valve. This dilutes the incoming air/fuel mixture and has a quenching effect on combustion temperatures which keeps NOX within acceptable limits. As an added benefit, it also reduces the engine's octane requirements which lessens the danger of detonation (spark knock).
Old October 27th, 2011, 06:22 PM   #26
so why would i take it off.?
Old October 27th, 2011, 06:49 PM   #27
1994 Mustang Cobra
for performance you want to lower the inlet air temp as much as you can and getting rid of the egr is one of those ways I got ride of mine as soon as i got the car I just took the cross over tube between the heads off and plugged the hole got ride of the smog pump and pulled the egr off and blocked it off at the tb if your going for performance you dont need it lol
Old October 27th, 2011, 08:27 PM   #28
lol then I don't need it.. but do you have a pic to show me where its at.?
Old October 27th, 2011, 09:24 PM   #29
1994 Mustang Cobra
if you look on your passenger side exhaust pipe there should be a pipe coming off there to an egr valve and on a fox i believe it connects between the throttle body and intake
Old October 27th, 2011, 09:30 PM   #30
well theres nothing sticking off my headers... and the only thing sticking off the rest of the exhaust system is an 02 sensor
Old October 27th, 2011, 09:35 PM   #31
1994 Mustang Cobra
I wonder is someone has allready removed the egr let me see if i can find a pic
Old October 27th, 2011, 09:39 PM   #32
1994 Mustang Cobra
its the one that the white vaccume line is plugged into
Old October 27th, 2011, 09:51 PM   #33
ryanw's Avatar
1991 Ford Mustang GT
Taking off the EGR may also cause your gas milage to go down. Id keep it if i were you. At low RPM the exhaust gases take up room in the combustion chamber, wich makes your car not need as much air and gas. Thats the short of it. Fogged306 exsplains it way better then me. Maybe if he sees this post, he will post his version.
Two of the benifits of taking it off is...the engine bay looks cleaner and yes you will have lower intake temp
But another negative is your computer will all ways have an error code(not a big deal though) unless you have it tune out of the computer.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 27th, 2011, 10:05 PM   #34
oh I don't have that on my car i got the thing that its plugged into but i don't ever recall something coming out of it at least not like that
Old October 27th, 2011, 10:11 PM   #35
1994 Mustang Cobra
does ur car have a chip in the ecu meaning it has a custom tune ?
Old October 27th, 2011, 10:22 PM   #36
not at all, does it have anything to do with the car being a 4cly car swapped over to a 5.0.?
Old October 28th, 2011, 11:45 AM   #37
1994 Mustang Cobra
it could be what all mods have been done to the motor like injectors, maf stuff like that
Old October 28th, 2011, 02:47 PM   #38
It probably had it in my old 5.0 thats where the engine came out of but it doesn't matter now thats gone
Threads Similar to: Tips on releasing horsepower.?
horsepower fleshbone Modular Mustangs 7 May 24th, 2009 02:18 AM
Problems with urathane releasing agent Chance Modular Mustangs 5 March 20th, 2009 06:32 PM
horsepower Murderjetz V6 Mustangs 8 March 19th, 2007 11:10 PM
Parking Brake not releasing... xx9gt6xx 96-98 3 October 13th, 2006 01:34 PM
