1995 Mustang GT
![]() iTrader: 2 reviews
Supercharger question
Alright you guys, im trying to save up for either a supercharger or a turbo charger..which way would you guys go?
If i were to get a supercharger, could i get one such as a kenne belle, to where i can screw onto the intake, or would i have to get one such as a vortech or procharger? I have been looking at turbos also, which one would be better for my 95 GT, and which one is easier to install and to tune? Thanks you guys, just been wondering this, and trying to save up my money right now for this..I think I might buy the cobra upgraded brakes first though, any ideas where i can find a real nice set of brakes for a good price? im talking about the rotors, calipers, and lines, or can i use my stock GT lines?
95 GT: JLTcai, Flow40s, o/r Xpipe, lowering springs, cobra brakes, cobra rims, sbfc, shocks/struts, trickflow170 heads (1.6rr), cobra intake, custom cam, 75mm MAF, 75mmtb, bbk shorty headers, 24#injectors, 3.73 gears, mach 1 chin spoiler.
1991 Ford Mustang GT
kenny bell makes a supercharger that bolts on to the lower intake of either a gt40/cobra or the stock intake.
turbo would make more power but the supercharger would be much easier of an install.
1995 Mustang GT
so if i were to get a kenne belle, i would need to get a gt40 intake?
#4 | |
1995 Mustang GT
Depending on how much work you want to do, I would say go with a supercharger. There are some turbo kits are available, like Hellion, but it will require a lot of plumbing and an intercooler. I personally am a fan of turbos, but if you want something super easy to install (compared to a turbo kit), a supercharger is hard to beat. For low boost, around 8psi or less, you could probably get away without having to use an intercooler. Of the 3 types available, the lysholm (or twin-screw) - which is what kenne bell is - is very hard to beat. You will get full boost starting around 2K rpms or so, all the way to your redline. The other types, roots and centrifugal, can get up to similar amounts of boost as the kenne bell, but have disadvantages. Roots are not efficient at all, and centrifugal are like turbos in that they have to "spool" so to speak - you won't get max boost until higher in the rpm range. The downside to the kenne bell is that it is more expensive then the other types. If your budget allows it, I'd suggest the kenne bell. If your budget doesn't allow it, I think you will still be happy with a centrifugal. The beauty of the supercharger is that it's very simple to install, and doesn't affect too much on the engine itself. Basically, you throw it on, perhaps adjust fueling according the to manufacture's instructions, maybe a piggy back, and away you go. Everything else can stay as it is. With a turbo kit, regardless of single or dual, you will have to do exhaust work, you will need new headers for the turbo, you will most likely need an intercooler unless you keep boost really low, you will probably need an air bypass valve if you run higher boost, you will need to do something with fueling, similar to the supercharger, etc. There's a lot more involved in the turbo kit, so really it comes down to how much effort you want to put into it. Oh, and the turbo kits usually are more expensive, more-so then a kenne bell, depending. Lastly, if you plan on running big boost, you *will* need to do some work to the engine if you want it to last a while. At the least, lower compression ratio pistons would not be a bad idea. If you are running low boost, then you can probably get by with the engine as is. I'm making a lot of assumptions here about your setup and what you want to achieve, so if I'm way off the mark or telling you something you already know, sorry about that. If I missed anything, or gave some bad advice, please someone call me out on it. |
1995 Mustang GT
1995 Mustang GT
wow thats some great information i didnt know mcglsr2, thanks...I really do like the kenne belle, but i do see that they tend to be more expensive..but i really want a supercharger i can bolt onto my intake like the kenne belle..as i am still pretty young, only 17, lol I think 7-8 psi would be plenty enough for me and my safety lol...i would rather not buy an intercooler, but if i need to i will...ive read some of the advantages and disadvantages of both turbos and superchargers, but leaning more towards a supercharger..and i have seen that turbos require so many extra parts such as headers and downpipes, etc...I want whats best for my car, so i will put effort into it to do it right, the first time..I dont think im going to cheap out, im probably just going to save this year, change my brakes, and hopefully have enough to buy a supercharger and put it on by the end of the school year going into summer
#7 | |
1995 Mustang GT
Regarding the kenne bell vs something else like a paxton or vortech - those last two might be options as well. A vortech or similar centrifugal is like half the price of the kenne bell. The install is easy as well, you add it on to the front of the car, like the other accessories (a/c, power steering, etc), and just route the output of the supercharger to the intake manifold. It's almost as easy as the kenne bell with regard to installation, so keep that in mind. From a purely technical standpoint, the kenne bell is the superior supercharger. However, the world doesn't usually work like that. Meaning this: if you plan to run 6 to 8 psi, do you really think you'll notice the difference between a kenne bell and a centrifugal? Sure, the kenne bell produces more boost and therefore more power across a wider rpm range. So, technically, it's faster. But with a centrifugal, you will still be making boost as you climb rpms, so your car will still be faster than it currently is. Could it be as fast if it had a kenne bell? Maybe not. But it also costs half the amount. So what I would suggest is this: think hard about how important to you that max boost across the rpm range is. Or is it good enough to just be faster? I notice you want to save up for a Cobra brake upgrade. I just did this on my 95, about $1K is what it took. For the price of the kenne bell, you could do a centrifugal AND your brake upgrade. In the end, it's your car, your call. You do what you feel is best. I'm just saying that, while on paper, in dyno charts, etc, the kenne bell looks better, and technically it is better, that doesn't mean you wouldn't be perfectly happy with a centrifugal, and have some money left over to boot. Real world differences are often easily blurred. If the goal is to make your car better, and money is a limiting factor, I would personally suggest a centrifugal and brake upgrade over the kenne bell. You will get more enjoyment out of your car. Is it as fast as it *could* be? No...but would you really notice? If the goal is to have the fastest car, then drop the supercharger entirely and go for a built bottom end with a twin turbo setup pushing 25psi to 30psi of boost... It's all about the trade-offs. By the way, the Cobra brake upgrade is MUUUUCH better than the stock GT brakes...the Cobra rear disc is larger than the stock GT front if that tells you anything
I my self im going the supercharger rout with next years tax return.
but as far as cost goes, the ON3 turbo is under 2000 dollars which is cheaper then a supercharger. but yes your going to need more parts to make a turbo work. the problem i see with the kenny bell supercharger is that you have to use either the stock intake or the gt40 intake, wich dont flow as much as other aftermarket intakes. i dont know about you but i hate being locked into one or two specific parts. Another problem with the roots, or cork sqrew superchargers like the kenny bell, is they get heat soaked more then the centrifugal supercharger. heat soaked means less power. you want the air entering your engine to be as cold as possible kenny bell doesnt have an intercooler. id lean towards the centrifugal...but thats just my two cents
1995 Mustang GT
Alright, thanks guys, lot of stuff i didnt know..i might be leaning towards a paxton s/c..whats the difference between paxton, vortech, and procharger?
1994 Mustang Cobra
I have a boost brothers turbo kit on my 94 sn95 and they run under 1500 for everything you would need including all the headers and intercooler. I have been running this kit for 3 years now with no issues and works great. As far as the install on my stock motor setup I was able to still keep everything including the ac and the hardest part was just putting on the headers but that only took about 2 hours for both sides if you want so more info just let me know yeah these are cheep kits but I have had really good luck with mine and still running the same turbo that came with the kit.
#11 | |
1995 Mustang GT
#12 | |
1995 Mustang GT
Lastly, just for clarification on the kenne bell efficiency (and no, I'm not a fanboi or anything), roots blowers and lysholm blowers (which the kenne bell is), while based on the same principle, are in different leagues when it comes to efficiency. Roots, because of the lack of precision between screws, is on something of the order of 50-60% efficiency. Lysholm screws, because of the greater precision, don't heat up the air as much during compression, and end up with something like a thermal efficiency of 70-80%. Which is really good. Modern turbos in the sweet spot crank out about 80% efficiency or so. Because of this, while heat soak is still an issue, and is on any FI setup, it's much more of an issue with a roots type blower (especially as psi increases) than it is with the kenne bell. That's part of the reason the kenne bell costs so much (not counting various markups), it costs more to manufacture the high precision screws. |
1995 Mustang GT
alright thank you guys, great information your giving me..i was looking on the corral and i found someone selling a complete vortech v1 supercharger for 1800 shipped..he said its been on his car for 3000 miles, but doesnt know how much the first owner had on it...he also says that he does not push it hard all the time, so idk if i should believe that or not...he sent me pictures of the s/c and its in terrific condition
#14 | |
Threads Similar to: Supercharger question
| Help! Supercharger question | marsgt | 99-04 | 20 | January 25th, 2011 05:07 PM |
| supercharger question | ralph30 | 96-98 | 5 | May 24th, 2010 11:04 PM |
| supercharger question | rider4life350 | 99-04 | 40 | February 19th, 2010 12:35 AM |
| supercharger question | mustang_jim85 | V6 Mustangs | 9 | October 26th, 2008 11:47 AM |
| Exhaust question + supercharger (warranty) question | r00st | 2005 - 2010 | 2 | January 31st, 2008 11:07 AM |
