1990 Mustang GT
Speedometer cable problem
When I bought my mustang, the speedometer cable was broke. I bought a new one and installed it the other day. I took my car for a drive today just to see if it would work. The needle slammed all the way past the numbers and now this cable is broken. Is it possible that the gear on the transmission is the wrong gear and caused the cable to break? Thanks.
1990 Mustang GT
Anyone?
1991 Ford Mustang GT
did you pull the cable back out to make sure its broken. I would have thought your gauge would have broke before the cable would have
1989 Mustang GT 5.0
My speedo doesnt work either, Its been years still doesnt work
2 trannys later New speedo cable New cluster Still doesnt work, i think its the lil gear at the end of the cable
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
When it comes to your speedo does it still count the milage or does nothing work ? If it still counts the milage it's most likely your gauge and not the speedo cable
1989 Mustang GT 5.0
Nothing
1990 Mustang GT
Yeah, I pulled the cable back out. It is broken. I called the manufacturer and they sent me a replacement. I'm going to check my gears in my rear end and order the correct gears for the transmission and speedometer cable.
Threads Similar to: Speedometer cable problem
| Speedometer cable removal | 91Mustang GT | 5.0 Mustangs | 2 | October 5th, 2010 08:28 PM |
| Speedometer cable bracket?! | laztug | 5.0 Mustangs | 11 | September 10th, 2009 02:32 AM |
| speedometer cable | 91cobra5.0 | 5.0 Mustangs | 5 | September 30th, 2008 10:14 AM |
| Quick speedometer cable question | Matt300ZXT | 5.0 Mustangs | 0 | August 5th, 2008 01:12 PM |
| How To Tell A Bad Speedometer Cable? | 5literJeff | 5.0 Mustangs | 1 | September 5th, 2006 12:30 PM |
