Things I noticed when doing the 5.0 swap into 4 cyl car - Forums at Modded Mustangs
post #1 of 7 Old June 6th, 2006, 11:03 AM Thread Starter
Electronic fuel pump on the Fox body cars is the same for the 4 cyl vs the 8 cyl.
The fuel lines can be easily removed from the 4 cyl, and moved to the 8 cyl. The 4 cyl is on the driver side, while the 8 cyl is on the passenger side.
Headlight/alt wiring is switched 180 degress on the 4 cyl/8cyl. The alt is on the driver side on the 4 cyl
Wiring harness is not bad to change over, I only found one connector that was different. It was the one that is on the driver's side of the car, and does not get swapped out. The one harness is a 3 plug, the other is a 2 plug. The wires are color coded, so just snip the connector off of the v8 and solder it to the 4 cyl harnesss. The wires are color coded, so I guess you don't even need the connector. One of the wires is not used anyway, and this will be easy to fiqure out. It is the one that is not there on the other harness :-)
The fitings for the cruise control/throttle are different, so take the ones off of the v8 car.
Update to post:
I tried to use the old 4 cyl wiring harness for the fusebox, but it would not work. Maybe if it is the same year, but the 4 cyl was a 89 and the 8 cyl was a 90, and there were alot of changes from 89 to 90. I went back to the salvage yard, and got the complete harness, and I do mean complete from the same car that I got the engine. I was having problems with the fuel pump, horn, lights, etc. Now all is ok.
Wow, this has been one heck of a project
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
OTreborO is offline
post #2 of 7 Old June 6th, 2006, 11:20 AM
Good post. Thanks for sharing.
orangeRcode is offline
post #3 of 7 Old June 6th, 2006, 12:29 PM Thread Starter
Brakes
I also changed the front springs to the 8 cyl car springs, the rear springs are the same, but I pulled them all, and put new coil spring insulators, available at autozone in black or red. Front part number 4.6102G, rear part number 4.6101G. I also put new sway bar to lower control arm hardware and rubber, again from autozone in red or black. When installing the sway bar I found out that I had to connect the lower control arm to sway bar hardware first, then lift up on the sway bar, and start the bolts that attach it to the frame. If I attached the sway bar first, I wasn't able to connect the other hardware. This may have been because the engine was not in the car.
If you use the v8 front brakes, which I suggest, you will also need the little bracket that connects the flexible brake hose to the solid brake line. This clip/bracket attaches to the car, and is different for the 4 cyl brakes vs the 8 cyl brakes.
Oh yeah, I also changed the rack and pinnion steering because the fittings on the v8 pump are different than the 4 cyl pump, the v8 also has an extra length of tubing for the fluid, I guess for cooling??? It is mounted in front of the radiator, and goes through the frame on the drivers side, and circulates the fluid.
If you are not having fun yet, I suggest you go ahead and also change out the heater core.
Enjoy
OTreborO is offline
post #4 of 7 Old June 6th, 2006, 06:45 PM
AtlanticBlue99's Avatar
Great info!
ModdedAutos
1999 Mustang V6
AtlanticBlue99 is offline
post #5 of 7 Old June 6th, 2006, 11:55 PM
stang fanatic's Avatar
yo are correct on the p/s tubing...it was to cool the fluid cause the v8 typically had the sport steering set up
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
stang fanatic is offline
post #6 of 7 Old June 14th, 2006, 11:40 PM
ttop5.0's Avatar
good info bro, thanks
ttop5.0 is offline
post #7 of 7 Old July 26th, 2006, 05:47 PM
If I remember correctly that extra fitting on the 4 cyl p/s is a WOT cutout switch to give the 4 banger more power when hitting the gas. You still have that hose? Do you want the car to hook or corner? in reference to swapping the 4 cyl springs - Yeah I was little suprised to find the 88 liter Fuel Pump on an 88 4 -Banger was the same as a 86GT - I reasoned then that Ford worked out the kinks on the 86GT since it also had a smaller throttle body then the 87s ( I believe 55 mm vs 58 mm)
wv_horse_trader is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/2377-things-i-noticed-when-doing-5-0-swap-into-4-cyl-car.html
Untitled document This thread Refback April 17th, 2013 06:21 AM
