1989 Mustang GT 5.0
Finally cage has started!
Ordered my 10 pt from summit a few weeks back, cleaned em up with rubbing alcohol, grey primer, one coat of base matte black
Started welding the main hoop! Pics will come
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
1989 Mustang GT 5.0
1991 Ford Mustang GT
do you have to get the cage certified to run it on a track ?
Awesome start so far. Hope all goes well.
![]() Sig by Tricep |
1994 Mustang Cobra
hey when ur done there come on over lol looks nice keep the pics coming
1989 Mustang GT 5.0
No idea on "tracks". Im gonna road race so idk what they want my buddy build drag cars with his dad, he is a certified mig tig and stick welder. Not to worried itll be sone right. And for free
he has a 1398hp twin turbo nitrous 8.20 drag fox body back home.And a twin carb blown 67 nova that put down 980hp He knows what he is doing his daily is a clean 93 gt black looks like mine except chrome cobra r wheels and a small cowl hood. Built 331 tf goodies Im in nc now so how do u want me to come down lol
1989 Mustang GT 5.0
1989 Mustang GT 5.0
I like the fact that you didnt run the cage into the quarter panelwheel wells. thats what id like to do cuz i dont want to cut into the plastic quarter panels
1988 lx
9.68@142
i cant see the pics but just a heads up for you and maybe some suggestions.
1) lightly tack the entire cage in place with the 6"x6" 1/8" steel plates sitting under the poles. 2) remove the steel plates and mark where the bars are resting on the floor. 3) take the cage out of the car use a hole saw and cut out the area where the cage will sit. 4)tack the cage very good back in place where the cage will sit. 5)remove the plates and drop the cage as low as possible through the floor 6) weld the tops of the bars where you wont be able to get to when the cage is in place 7) lift the cage back into position and finish welding everything. 8)now weld the bottom where you cut the hole to the plates. you might not want to go this far for what you are doing but if you ever decide to sell the car or want to get it certed the tops of the bars need to be welded or you have to have ugly ass gussets in each corner. and trust me even if you think you will never let your car go now that might change in the future. i know from personal expierence on that one.
1989 Mustang GT 5.0
.... 8 pt is already done....
1988 lx
9.68@142
nice
1989 Mustang GT 5.0
Gonna do some braces for rear shock towers, since im runnig coilovers. We have extra beams. And tomorrow finish the two dash bars
Awesome progress on your cage. What color you gonna do when its all done.
1989 Mustang GT 5.0
Matte black,
I just had the car up on one jack under the subframe connectors next to the right rear wheel, both right side wheels completly off the ground i open the passenger side door and the car came up off the ground on the driver rear side. Lmao!!! 1 jack 3 wheels off the ground! I think that stiff!!!
1989 Mustang GT 5.0
1989 Mustang GT 5.0
Custom rear shock tower braces. Used 3 gassets each side from the kit
89 GT
You're not getting much penetration with those welds.... Are you stick welding that?
1989 Mustang GT 5.0
My friend is a certified welder and he is doin the welding for me. Its mig
1989 Mustang GT 5.0
I didnt want to burn thro the shock tower
Threads Similar to: Finally cage has started!
| Turbo install (finally) started | ESP v6 | 2005 - 2010 V6 | 14 | August 15th, 2011 01:10 AM |
| finally started the install | psycho bob | 2005 - 2010 | 27 | October 18th, 2010 10:12 AM |
| started my journey...finally | balls8302 | The Clubhouse | 11 | July 14th, 2009 09:51 PM |
| 351w build finally started | chaosstangman | 5.0 Mustangs | 7 | April 2nd, 2009 06:05 PM |
| finally gonna get this started (408 stroker) | chaosstangman | 5.0 Mustangs | 3 | March 6th, 2008 12:37 PM |
