header bolt missing
So i was looking at my driver side header and notice a header bolt is missing. I was going to replace the gasket Mon anywa ? is will it be OK to drive its my drive and i work all weekend. Also is the driver side header as hard to get back on and lined up as the pass side i had alot of problems last time try hey are Mac pro shorts
1991 Ford Mustang GT
Is the bolt missing or is it broke off in the cylinder head ? I have only swaped header with the engine out ofthe car so I have no idea witch side is harder to work on
Its just missing i tried to put a new one in but it was not lined and started cross threading
I'd try to get a tap to thread in correctly before you try again. If you can't then
1969 Mustang Mach 1
6.824@101.61
Loosen all the other bolts off a few turns, replace missing bolt, tighten all bolts. Headers tend to that if you don't snug them up occasionally.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
OK i had a couple hours between classes today and tried losen all the bolts but can't get it lined up loosened the headers from the hpipe also no luck. I think I'm going to have and take the whole thing apart unless u have any other ideas? Do u think i will hurt anything by driving it over the weekend it doesn't seem to be leaking alot but can hear that it is.
your not going to hurt any thing
Ok cool thanks guys hopefully I can get it back on easy with everything off
1991 gt vert
bolt missing is a common problem with headers like 69fastback said.
bolts not lining up is a common problem with the mac headers!! |
1969 Mustang Mach 1
6.824@101.61
Man sometimes it's just a PITA. If you keep working at it, it will go.
1984 Cougar GT
yes, M.A.C. shorties are horriable about bolts not lining up. i know i have a set. XD
well i got the header back took about 4 hours had to take all the exhaust off. But started the car and now i noticed i have a horrible ticking sound, thought it was a leak but everything was tight. So now I guess i have to take it in to a mechanic. Its coming from the top of the motor on the driver side head, any ideas and how much on average it is to fix, im a broke college kid. Starting to think the guy i bought her from lied about the rebuild this is not the best dd love the car but its problem after problem.
That's the thing with 20 year old cars. There going need money. I'd never recommend a 20 year old car as dd . Unless every thing has been replaced or your a master at working on cars. I think of these cars as fun weekend project cars. Nothing more. Just my opinion
1969 Mustang Mach 1
6.824@101.61
So the tick just started? Did you replace the header gasket?
im not sure i have never noticed the tick before its not horribly loud, yeah i replaced the gasket the gasket did get pretty bent up when i was trying to put the header back on, but i straightened it up before i got it all together.
hey so i figured out what the sound was I cracked my header at the flange. so now the question is what headers should i get now looking at these 1986-93 Mustang 5.0L BBK Chrome Equal Length Headers, will these bolt straight up. Any input would be nice going to order tonight if i can.
I bought a set of jet hot coated hedman hedders and they look great and bolted up easily. pretty cheap too. if you just call jet hot you can order them direct from them. a lot cheaper than getting ceramic coated hedders direct.
Threads Similar to: header bolt missing
| Intake Manifold Ground and Bolt Missing | Ruffellbaker | General Tech | 1 | March 25th, 2011 11:39 PM |
| LT Header bolt | N29468 | V6 Mustangs | 14 | March 30th, 2010 01:14 AM |
| header bolt size? | Chris951 | 5.0 Mustangs | 7 | March 30th, 2009 12:48 AM |
| missing bolt hole on intake manifold | hardhitter | 99-04 | 2 | January 16th, 2009 05:47 PM |
| Header bolt... | Till | 5.0 Mustangs | 29 | February 18th, 2008 07:50 PM |
