1992 Lx hatch
ODD question, please help
Between the engine and bellhousing, there is a thin meatl plate not sure what its fore but all i know is i dont have one and i would like to findout if its needed before i begin putting the flywheel on and clutch,
please let me know, and if it is needed what is the name ? Thanks! |
1991 Ford Mustang GT
I know what your talking about, and i have one on my car, not sure what its for. But i would say that you need it. i think there less then 50 bucks from summit
1984 Cougar GT
is it the rock cover? so rocks dont get in there and dust and shit?
1989 Black LX---Turbo
If you don't have it you will break the ear off of the starter in a short time. The hole for the starter actually supports the thrust of the starter. I tried running without and found this out first hand!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1988 lx
9.68@142
it is called a blocking plate and it is important. not only does it space out the transmission from the engine just slightly it is also an alignment tool for the starter. it uses the dowells on the block to line the starter up. ive gotten away without them but its not worth the hassel clean it up and put it in. it goes on befor the flywheel too.
Threads Similar to: ODD question, please help
| quick question. fuel rail question on mark viii swap | Speedy1221 | 99-04 | 7 | October 12th, 2011 11:02 PM |
| pro 5.0 shifter question + smog pump elimator bracket question | GMcanblowmyFORD | 5.0 Mustangs | 6 | June 28th, 2011 09:29 PM |
| cam with nitrous question, frpp manifold intake question | slater | 2005 - 2010 | 57 | November 14th, 2010 05:40 PM |
| Exhaust question and tuner question.....dont laugh lol | Drick | 99-04 | 19 | September 24th, 2009 03:42 PM |
| Muffler question (visual aspect) + Emblem question | warrior86 | Visual | 5 | November 20th, 2007 09:55 PM |
