Coolant Fan woes...
Old October 29th, 2011, 05:42 PM   #1
Sinatra's Avatar
Sinatra is on a distinguished road
Coolant Fan woes...
After giving up on the problem and trying to ghetto rig my fan only to burn up a ton of relays, it's time to ask the experts
What I know:
*Problem started when I blew a hose from the water pump.
Changed the CCRM, no change.
Tested the Ohms on the temp sending units, all normal
The fan definitely works, I hooked it into the battery. But it does not turn on when I know the engine is getting too hot.
No matter how hot the engine gets, the temperature gauge only moves past the 1st dash, but it does move.
So tired of driving around like a grandma and turning the engine off at every stop light. I'm hungry, please feed me
Old October 29th, 2011, 06:34 PM   #2
1994 Mustang Cobra
steveofire is on a distinguished road
if you want the fan to come on all the time for now just run a ground to the wire with the green with purple strip on the ccrm this will put the cooling fan on high all the time
Old October 29th, 2011, 07:49 PM   #3
e3sean's Avatar
1988 lx
9.68@142
What I know:
well by the sound of it, the water hose had nothing to do with the fan not working.. the hose blowing was proly caused by the fan not working. sounds like the tempeture switch went out. if it cant be replaced wire in an aftermarket one in. they sell them at your local autoparts stores for like 35.00
<font size=4><b>MILITARY CREW
Old October 29th, 2011, 08:18 PM   #4
Sinatra's Avatar
Where is the temp switch located?
Old October 29th, 2011, 08:38 PM   #5
e3sean's Avatar
1988 lx
9.68@142
not sure on your car its gotta be on or in the radiator. or it uses the water temp sensor. im not sure. but if it kicks on and off it uses something. pull your fan off and see if there is something inside that looks like a relay. find where the fan gets its power from is it a switch of some kind (a small box) or does it come stright from the wire harness?
Old October 30th, 2011, 09:56 AM   #6
Sinatra's Avatar
I will definitely look for the switch. What about the thermostat? Could that have something to do with the fan not kicking in?
Old October 30th, 2011, 11:03 AM   #7
1994 Mustang Cobra
what year is your stang?
Old October 30th, 2011, 11:08 AM   #8
e3sean's Avatar
1988 lx
9.68@142
i suppose it could uausally the engine would overheat before the hose would blow. is the radiator getting hot?
Old October 30th, 2011, 05:46 PM   #9
Sinatra's Avatar
Yeah it's getting hot. My stang is a 94. I just got it, I know you shouldn't go for first years but for 2300 bucks you can't go wrong.
Old October 31st, 2011, 04:59 PM   #10
Sinatra's Avatar
I go to a technical institute and spent more time installing a short throw than the fan :-X. But I did rule out the thermostat, seems to be opening and closing pretty normally. That is, if I have the correct temperature, I believe it said 210?
Tomorrow I'm going to look for that switch underneath the radiator. Hopefully this is it.
I also must curse OBD1!!!
Old October 31st, 2011, 05:03 PM   #11
1994 Mustang Cobra
being a 94 stang your sensor is going to be in the metal pipe coming out of the front right side of the intake those metal tubes also run to your heater core that is the sensor that tells your fan when to come on and off and also tells the ecu how hot or cold the engine is running
Old October 31st, 2011, 06:27 PM   #12
Sinatra's Avatar
Is that assembly sealed with a gasket or silicone?
Old October 31st, 2011, 06:48 PM   #13
1994 Mustang Cobra
the sensor is a white 2 wire sensor that is screwed in and has silicone on the threads on a new one
Old October 31st, 2011, 06:52 PM   #14
1994 Mustang Cobra
Old November 2nd, 2011, 05:18 PM   #15
Sinatra's Avatar
So I changed the sensor with a brand new one and all hell broke loose. Gas some how wasn't being sent to the engine, it was misfiring like crazy and to top it all off my coolant boiled over and soaked the place. Took a good hour just to get it to start.
Checked literally everything, nothing worked. Pulled out the new sensor, stuck in the old on. No problems.
My next thread will probably involve questions about carbing my 5.0...
Old November 2nd, 2011, 05:23 PM   #16
1994 Mustang Cobra
I have had that happen with my wifes car once I bought a brand new one and got back home installed it in the car and the car wound't start at all I was like wtf so I took it back and got another new one and put that one in and fired right up sometimes you can get a bad one take it back and get another new one and as for going carb I can help ya there That is what I am in the process of doing now for your car it would be easy I will take a pic of some of the parts i just got in and give ya some advice it's the only way to go
94 Cobra
351w .040 over
DSS Forged Pistons
Scat Rods
TFTW Heads 2.205 Intake 1.62 Exhaust
Trick Flow R Intake
750Cc RC Injectors
Aeromotive A1000 pump and Reg
Boost Brothers Turbo Kit
Old November 2nd, 2011, 06:20 PM   #17
Sinatra's Avatar
Yeah man I figure I wont have to worry about bad wiring making everything shut off and/or explode lol.
Will It loose power and gas mileage?
Old November 2nd, 2011, 06:28 PM   #18
1994 Mustang Cobra
It can as that sensor will tell the ecu what temp the motor is so it will control fuel and timing so if it is saying the motor is really hot it will pull timing and dump more fuel trying to cool it down
94 Cobra
351w .040 over
DSS Forged Pistons
Scat Rods
Trick Flow R Intake
750Cc RC Injectors
Old November 3rd, 2011, 04:19 PM   #19
Sinatra's Avatar
Problem found, nice. 115 bucks...damn it. Need a new fan motor. Even though the fan does turn on when you wire it to the battery, its shitting out too way too many ohms, which would explain why its melting everything. The motor itself is shorted, everything is stuck open in there. Damn it.
Getting the new fan tomorrow.
Old November 3rd, 2011, 08:15 PM   #20
1994 Mustang Cobra
Just go to a junk yard those fan usally last a long time
94 Cobra
351w .040 over
DSS Forged Pistons
Scat Rods
Trick Flow R Intake
750Cc RC Injectors
Threads Similar to: Coolant Fan woes...
5.0 woes JoeB 5.0 Mustangs 14 September 21st, 2010 09:19 PM
Coolant tube Woes.. blkragtop 99-04 11 July 5th, 2010 10:29 AM
coolant leaked out of my coolant cap? mustangracer2g 96-98 20 March 16th, 2009 01:22 AM
My woes zinc02GT The Clubhouse 26 December 26th, 2008 08:11 PM
Air Bag woes GreenFaleen The Clubhouse 18 April 27th, 2007 12:30 AM
