95 Cobra, Stock Engine with 28,000 Miles...Need Upgrade Advice!
Old October 30th, 2011, 12:10 AM   #1
1995 Ford Mustang Cobra
95WhiteSnake is on a distinguished road
Ok, So i just bought my 2nd Mustang...My first was a 94' GT (Wrecked it in high school...Silly kids!)....10 years later I finally got my dream car...1995 Cobra..
The car has been owned by a 59 yr. old who only drove it on the weekends...this car is a gem....28k original miles
Here is a list of what has been done to it so far:
* 3.73 gears with eaton posi unit
* maximum motorsport frame tie connectors
* maximum motorsport lowering kit with coil over set up
* tokiko double adjust shocks
* 8.8 differential girdle
* maximum motorsport upper and lower control arms and front and rear sway bars
* steeda caster camber plates
* upgraded t-5 transmission
* clear side marker lights
* ford shorty headers
* urethane bushings
* cold air package with upgraded MAF
* Gibson 3" cat back system
* king cobra clutch
* slotted brake rotors with upgraded brake package
* Cobra R wheels
* Nitto drag radials
* short throw B&M shifter
* Ford Motorsport plug wires
* upgraded headlights
* 4" cowl hood
I have about $6,000 saved up for future mods....I just dont know what I want to do. I do know I want a Turbo system...but thats really about it....
I need some advice on what I can do to add some hp and what I can add under the hood...
Please remember...I'm 28 yrs. old and NOT looking for a drag car...I just want something nice that will last me forever...But want the power at my fingertips for those "feelin' froggy" days!!!
Any advice is welcomed!
Old October 30th, 2011, 12:18 AM   #2
1992 Mustang GT
dont know yet
96paxtonstang is on a distinguished road
Throw a set if heads on it. Trickflows top end kit will put you around 300-310 depending on the kit which includes heads, cam, upper and lower intake. And that will put you in great shape for when you are ready to throw some boost at it. May want to think about doing some work on that bottom end also as it isn't forged.
Sent from my Autoguide iPhone app
______________
Mods:
Paxton Novi 2000 @10psi
3.73 gears
255lph fuel pump
Lucas 42# injectors
Trick Flow 75mm upper intake
Trick Flow 75mm throttle body
Diablo "MAFia"
Dyno tuned by Force Fed performance Sacramento Ca
Old October 30th, 2011, 10:33 AM   #3
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Did you buy this car locally?
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old October 30th, 2011, 10:58 AM   #4
I did, bought it in Edmond.... Have you seen it before?
White 1995 Mustang Cobra...28k Original Miles...
Old October 30th, 2011, 11:08 AM   #5
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I think I have. Do you know if the guy was an OMC member?
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 30th, 2011, 11:09 AM   #6
1994 Mustang Cobra
steveofire is on a distinguished road
with my stock 94 cobra motor meaning heads, intake, cam, bottom end I just put on the boost brothers turbo kit with a different maf and injectors and pump I was at a consertivive tune on 92 pump gas at 414hp and 540tq
Old October 30th, 2011, 11:18 AM   #7
I couldnt tell ya to be honest....I need to join OMC so I can learn more about these cars!!!! Are you a member?
Old October 30th, 2011, 11:37 AM   #8
brody904's Avatar
12.9@113
brody904 has a spectacular aura aboutbrody904 has a spectacular aura about
Post some pics of this thing! I'm really interested to see it!!!
Blown
390rwhp, 389ft-lbs at 11.9psi (See garage)
Old October 30th, 2011, 11:50 AM   #9
91cobra5.0's Avatar
98 Cobra
hyper pistons and the gt40 heads will take you to the limits of the stock block and be fine as long as you get a proper tune. no need to upgrade either unless you plan on changing blocks.
get some bigger injectors and a bigger pump, add that turbo, an aluminum drive shaft, and drop down to 3:55 gears, and a custom cam, or atleast a different than stock cam (something to compliment the turbo), a different intake would also be a good upgrade.
if i were gona build a turbo car i would try and focus on some low end rpm power since that turbo will carry you thru the higher rpms
Old October 30th, 2011, 11:58 AM   #10
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
No, I'm not. I frequent the Deadhorse crew, but I know a lot of the OMC guys.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 30th, 2011, 05:09 PM   #11
How do I get the pictures small enough for the forum to upload them? I have tried several times and it never works...
Old October 30th, 2011, 05:12 PM   #12
fogged306's Avatar
89 GT
Use a filehost like photobucket or tinypic ect..
Old October 30th, 2011, 05:27 PM   #13
brody904's Avatar
12.9@113
Photobucket works great. Just use the IMG code...
Blown
Old October 30th, 2011, 06:25 PM   #14
Pictures by JCraigKelley - Photobucket
I think that link should work....I kept trying to upload the images but it keeps telling me that the file is too big...that was from the photobucket link too....
Threads Similar to: 95 Cobra, Stock Engine with 28,000 Miles...Need Upgrade Advice!
Will the Ford Racing Cobra Brake Upgrade Kit work on stock 2001 gt wheels? RanGer498 99-04 16 March 12th, 2008 04:01 PM
Ford Racing Cobra Brake Upgrade Kit on a GT and stock wheels RanGer498 99-04 2 February 26th, 2008 02:28 PM
1995 5.0 HO Upgrade Advice mustang1995_5.0 94-95 22 January 7th, 2008 12:08 PM
