1989 Mustang GT 5.0
Quarter horse / BE users need some help
Im going back to all motor, Is there a way on binary editor to bring the ecu back to a factory a9l tune?
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
89 GT
Yea, just load the original A9L bin.
1992 Mustang GT
Coming soon...
Why you ditching the turbo set up?
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work |
1989 Mustang GT 5.0
But i think my a9l bin is setup for 42lb jectors and boost...
Im selling the turbo setup to my friend who runnig 302 w c4 drag setup I miss the throttle response and consistency of na. It will be better for road racing
89 GT
You can re-download a stock A9L def file if you saved over your original.. Check moates.net, or search on EECtuning.org, or just google for one. I know I've seen them available all over the place, just can't remember where off the top of my head.
1989 Mustang GT 5.0
And i need to send my maf and get that calibrated for 19s ....
89 GT
No, you need the transfer curve for it and just input it into BE. No need to have a MAF that matches your injector size when you have a quarterhorse.
1989 Mustang GT 5.0
. So tune the transfer function on the maf
1991 Ford Mustang GT
with your top end kit, dont you think you should run 24lb injectors ?
1989 Mustang GT 5.0
Damnit. Idk. I made 213 rwhp with bolt ons. Whatd u think im up to at the wheels with a track heat intake and pro comp 190 heads?
I have no clue what your HP is. But i figure stock engine = stock fuel injectors. And after market heads and intake was a good time to bump up to the next size injectors witch would be 24lb. You may be fine with the stock 19, but i dont think 24 will hurt you either
1989 Mustang GT 5.0
Well i will see what happens, i need to find out what are the ideal afr at wot for all motor as well
89 GT
Different for every engine. 12.5 is a good starting point.. First get your LAMBSE's to match your wideband readings by adjusting your MAF curve, then check your duty cycle on the injectors and see if you've got enough. You probably won't tho with those heads and 19's. Even though they aren't great quality heads, they are more capable than stock heads.
Threads Similar to: Quarter horse / BE users need some help
| Quarter Horse Help | BlwnStang92 | 5.0 Mustangs | 6 | June 21st, 2011 06:43 PM |
| Need quarter horse now? yes,no,maybe so? | Smokestang88 | 2.3 Mustangs | 2 | March 2nd, 2011 09:52 AM |
| Moates Quarter Horse | Cgross609 | 2.3 Mustangs | 26 | February 9th, 2011 11:16 PM |
| Quarter horse | flattusmaximus78 | 5.0 Mustangs | 22 | January 18th, 2010 12:46 PM |
| any one use Quarter Horse tuner? | EscortSportage | 5.0 Mustangs | 7 | August 25th, 2009 02:27 PM |
