306 Build suggestions
Old October 30th, 2011, 05:44 PM   #1
mrtwicepipes is on a distinguished road
Hey Im nearly complete with my build heres my list of completed parts,
30 over forged aluminum 10.13;1 comp pistons
ARP rod bolts
Stock crank and rods
AFR 165 heads w/ 58cc chamber
Crane 1.7 RR
Toped off with a trick flow street intake
65mm TB
70mm mas air
Of coarse the usual question of what prime model number cam to run...?
I have my eyes set on the comp cam 274 pros/cons
I have 1.7 crane rr this cam puts me right at or below 600 lift and I have the springs shimmed just for them but if there is another cam that has been used in your simular build or an opinion let me know.
By the way this is my first SBF build, Ive got a stock 90 fox I picked up a year ago.. and I cant leave anything alone. Daily driver with a car seat
Old October 30th, 2011, 06:49 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
why did you pick AFR 165 over all the other choices out there. Did you get a good deal on them ? Im not talking shit on them cuz i run AFR 185. I just think the 165 are just a tad small
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 30th, 2011, 07:33 PM   #3
Talking
Well a good dealis the answer to that, for 700 I got AFR heads, Crane 1.7 RR and push rods. No complaints here
Old October 30th, 2011, 09:53 PM   #4
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
That's not bad, but there's a real good chance you won't be able to use those pushrods. The only way to know pushrod length is to get your engine assembled, and then measure. Someone else's engine with the same parts can still use a different length pushrod, and valvetrain geometry is very important.
The XE274HR would be a good camshaft for the combo. It should make decent power with that. Because of the smallish heads, I'd say 305-315ish to the tires, and streetable.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old October 30th, 2011, 09:56 PM   #5
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Looking at that again, have you calculated the compression? Is it 10.13 calculated for your engine? With a 58cc chamber, and those pistons, it could be getting up there depending on the other variables. It may make more if it has higher compression.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 30th, 2011, 11:43 PM   #6
I've read some good threads about the cam working well with non-stroked engines plus its a 112 lsa so it should have a decent idle, yes according to the piston manufactor specs 10.13 comp on a 58cc head but I'm sure its ballpark right around there.
Old October 30th, 2011, 11:54 PM   #7
Hey by the way nice 69', I've been doing the body work on a 70' notch for the last 2 years on the side its gonna be sexy to say the least. Love the body style
Old October 31st, 2011, 10:05 AM   #8
1994 Mustang Cobra
steveofire is on a distinguished road
One way you could go is either call up summit racing or comp cams and give them all the specs on your motor and they will put it into there program that will give you the best cam for your combo I had a custom ground cam from com cams and I love it
Threads Similar to: 306 Build suggestions
Suspension Build - Suggestions? Shaun03GT 99-04 69 October 1st, 2010 02:45 PM
New build suggestions 94blakonblak 5.0 Mustangs 0 March 13th, 2010 04:58 PM
306 Build Suggestions Uber88GT 5.0 Mustangs 10 January 18th, 2010 10:36 PM
What to do build? Suggestions Falcon20 5.0 Mustangs 6 September 24th, 2009 11:08 PM
gaming pc build suggestions whiteboycustom The Clubhouse 34 February 7th, 2008 08:39 PM
