1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
e85 on 11:1 compression
I will be running 11:1 compression on my 351w motor. Running this compression would I be better off running e85 or 93 octane.
I know fuel consumption will go down but I don't want this taken into account. It won't be a daily driver so I don't care much for the mpg. -I haven't worked on upping my fuel system yet but the whole thing is getting redone. -Motor is carburated. -I live in Wisconsin so there's e85 stations all over. Thanks
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
E85 is 104 octane i believe. So you can pack more timing into it, plus the extra fuel in the chamber will raise your dynamic compression ratio.
1991 Mustang LX 2.3L 5 Speed convert 1989 Ranger 4X4 2.3L 5 Speed Entire turbo kit waiting to be used again. |
1969 Mustang Mach 1
6.824@101.61
If you can set it up for E85, it'll do much better.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1994 Mustang Cobra
e85 is 105 octane durning the summer but when it gets close to winter they change it to e70 which will run a lot richer but like the other guys said you will love it I switched his year my self and love it I was able to run 5 degrees more timing with the turbo, Intake charge went down as e85 burns cooler. one draw back is you have to change your oil more often because of the deposits in e85 but for the price you pay for gallon and the performance you get out it well worth the switch over
1989 Black LX---Turbo
We've been running E85 in my son's 87 Notch 12:1 427w bracket racer for the past 3 summers. We had the carb converted to E85 by Pro Systems(awsome carb). It does burn alot more(we went from mid 80's jets to 101/105)for E85. ProSystems also told us a 220GPH fuel pump minimum. We use a BG 280. Also takes quite a while to get up to operating temp(burns much cooler), but after a run it cools back down quick. And yes, you can smell it in your oil after a couple weekends. Don't try to run the car in a garage, the fumes stink something terrible!!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1 Wheel Peel
2000 Mustang 393w
I was going to go overkill with the fuel pump anyways. The only cost difference will be the carb. I am sure I can find a deal somewhere on one.
Horsepowerjunkie. What kind of fuel line are you running? Stock or a different style?
#7 | |
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 Last edited by horsepowerjunkie; October 31st, 2011 at 11:27 AM. |
Threads Similar to: e85 on 11:1 compression
| compression 9 to 1 VS. 11 to 1 | ryanw | 5.0 Mustangs | 6 | November 13th, 2010 09:18 AM |
| Compression Help | Spoonep3 | 5.0 Mustangs | 6 | April 14th, 2010 10:23 AM |
| Compression? | Timm10221 | 5.0 Mustangs | 6 | April 6th, 2010 10:17 PM |
| Max Compression | Goblin | 5.0 Mustangs | 8 | April 3rd, 2008 01:52 PM |
| Compression | Blackblurr_00GT | 99-04 | 7 | January 1st, 2008 01:14 PM |
